Pies wrote:How does one go about using silvertop quads in a map sensored setup? as apposed to afm...
Simon85MR220v wrote:I "think" there might be a vacuum pickup you can use off each of the TB's but you will also need some sort of damper to smooth out the vacuum pulses, especially lower in the rev range.
