avinesh wrote:hey guys just wana know if soarer with 1jzgte, with 3" exhaust front mount an intake on 98 octane fuel an two bottles of octane booster can handle 18psi for a couple of runs down the track......
the fallen303 wrote:17psi for bout a decade now, still going strong, custom 3" dumps done two years ago, helped a lot! if everything is stock, just bcd, i wouldn't bother with over 15psi, i ran a back to back dyno run with 16 and 20psi, and only gained i think 4-5rwkw? the 12a's just add too much heat above 16psi.
postfach wrote:no, as john said, the turbos heat the air too much, heat kills power, it doesn't matter what intercooler you have, there is always a point where you can't cool the air enough for it to be useful. ct12a's are small and inefficient turbos, you're better off keeping the boost lower, prolonging turbo life, and practicing your driving to get better times.
the fallen303 wrote:i'm running about 240rwkw on stock turbo's, but have tried upping the boost and did not see enough of a gain to warrant the stress on everything. you have to remember when the air gets too hot going into the engine, detonation becomes an issue as well, so even if you dont care about the turbo's, it might take your engine with them! we custom made our dump pipes, so bit hard to find anything similar
