soarer max boost
soarer max boost
Postby avinesh » Fri Sep 14, 2007 8:56 pm
hey guys just wana know if soarer with 1jzgte, with 3" exhaust front mount an intake on 98 octane fuel an two bottles of octane booster can handle 18psi for a couple of runs down the track......
avinesh
Postby method » Fri Sep 14, 2007 10:56 pm
I wouldnt bother with octane booster.
Run a petrol ethanol mix if you want to boost your octane, or a bit of avgas.
Octane booster damages O2 sensors and spark plugs. And hardly boosts octane at all, 98 is already full of octane boosters.
PICS UPDATED DAILY
method
Re: soarer max boost
Postby Lith » Sat Sep 15, 2007 12:03 am
avinesh wrote:hey guys just wana know if soarer with 1jzgte, with 3" exhaust front mount an intake on 98 octane fuel an two bottles of octane booster can handle 18psi for a couple of runs down the track......
Are they not ceramic turbos on those things? :? Just go with water or water/meth injection :D
2007 Mazdaspeed Axela
Lith
Postby edwagon » Sat Sep 15, 2007 10:00 am
1. They boostcut at 14psi (if you don't have a fcd installed)
2. The ceramic turbines fall off at 14psi
The engine will happily take 18psi, but as far as the turbos themselves go, it will litterally be russian roulette.
You'll probably find that those tiny little compressors won't flow much more at 18psi than at 13 or 14 anyway - just heating the air some more!
My experience with my own soarer (and any other powerful rwd car) is that you'll be far, far faster down the strip if you concentrate on getting it off the line cleanly. A few mph down the deep end will make sfa difference to your time in comparison to your launch.
LEt us know how you get on!
edwagon
Postby spencer » Sat Sep 15, 2007 4:17 pm
with custom dump pipes (best mod you could do on stock turbos) to get rid of the heat you could get away with 18psi if your turbos are in good nick. Check the shaft play most have heaps. Cressida forum guys have run 18psi for a couple years now no worries
ms63 crown
spencer
Postby the fallen303 » Sat Sep 15, 2007 4:49 pm
17psi for bout a decade now, still going strong, custom 3" dumps done two years ago, helped a lot! if everything is stock, just bcd, i wouldn't bother with over 15psi, i ran a back to back dyno run with 16 and 20psi, and only gained i think 4-5rwkw? the 12a's just add too much heat above 16psi.
true house of JZ
Stay true to the origin
the fallen303
Postby avinesh » Sat Sep 15, 2007 6:32 pm
the fallen303 wrote:17psi for bout a decade now, still going strong, custom 3" dumps done two years ago, helped a lot! if everything is stock, just bcd, i wouldn't bother with over 15psi, i ran a back to back dyno run with 16 and 20psi, and only gained i think 4-5rwkw? the 12a's just add too much heat above 16psi.
hey man where did your get dump pipes made
avinesh
Postby avinesh » Mon Sep 17, 2007 12:20 pm
so with front mount intercooler the car will not see much gain boosting around 18ish psi
avinesh
Postby postfach » Mon Sep 17, 2007 6:58 pm
no, as john said, the turbos heat the air too much, heat kills power, it doesn't matter what intercooler you have, there is always a point where you can't cool the air enough for it to be useful. ct12a's are small and inefficient turbos, you're better off keeping the boost lower, prolonging turbo life, and practicing your driving to get better times.
postfach
Postby Quirky » Mon Sep 17, 2007 7:15 pm
postfach wrote:... *crap*... practicing your driving to get better times.
^ what he siad
Hello There
Quirky
Postby avinesh » Mon Sep 17, 2007 7:46 pm
postfach wrote:no, as john said, the turbos heat the air too much, heat kills power, it doesn't matter what intercooler you have, there is always a point where you can't cool the air enough for it to be useful. ct12a's are small and inefficient turbos, you're better off keeping the boost lower, prolonging turbo life, and practicing your driving to get better times.
a soarer in aussie is running mid 11s on stock turbos at 20 something psi saw it on their soarer forum an also saw a vid of his run on youtube heres the link http://youtube.com/watch?v=tc_7aRUGshw .....his making good power as well i think over 250wkw with bolt ons an stock turbos
avinesh
Postby Mr.Phreak » Mon Sep 17, 2007 11:32 pm
Yeah, but Daniel expects his turbos to die a horrible death every time he goes down the strip.
And his car is a freak of nature
Mr.Phreak
Postby the fallen303 » Tue Sep 18, 2007 1:56 pm
i'm running about 240rwkw on stock turbo's, but have tried upping the boost and did not see enough of a gain to warrant the stress on everything. you have to remember when the air gets too hot going into the engine, detonation becomes an issue as well, so even if you dont care about the turbo's, it might take your engine with them! we custom made our dump pipes, so bit hard to find anything similar :P
true house of JZ
the fallen303
Postby avinesh » Tue Sep 18, 2007 3:46 pm
the fallen303 wrote:i'm running about 240rwkw on stock turbo's, but have tried upping the boost and did not see enough of a gain to warrant the stress on everything. you have to remember when the air gets too hot going into the engine, detonation becomes an issue as well, so even if you dont care about the turbo's, it might take your engine with them! we custom made our dump pipes, so bit hard to find anything similar :P
yea i tried finding dump pipes for 1jz almost impossible know of anyone selling/making them???
avinesh
Postby postfach » Wed Sep 19, 2007 11:54 pm
http://www.lexussoarer.com/
what you're looking for is there
postfach
Postby Mr.Phreak » Wed Sep 19, 2007 11:57 pm
Lew (Marlew Performance) was making them, but I think the price scares most people off
Ask Silent_Knight, from memory he was trying to track some down a while back before he got rich :lol:
Mr.Phreak
