1JZGTE waterpump
1JZGTE waterpump
Postby dirty rb » Wed Sep 19, 2007 10:54 am
Prob been covered before but....
I have a 1jzgte from a jzx90 running the waterpump with the hydraulic fan. Which pump is best to use as I dont want the hydo fan.
Which pulley will I need. Have a pulley from a 2JZGE but dont know if that will work on anything
Thanks Guys
dirty rb
Postby spencer » Wed Sep 19, 2007 2:05 pm
I just went to repco (only because of discount) and the item they listed was a non hydraulic fan version I had a 1jzge pulley and used that it all worked. Also get the cam belt and tensioner from toyota while your there didn't cost much. Also the other 1jz i had was from a jzz30 soarer it didn't have the hydralic fan. I recommend the supra forums for your 1jz questions theres shit loads on there and most stuffs been covered, only seems to be a handfull on here
ms63 crown
spencer
Postby Py7h0n » Wed Sep 19, 2007 2:26 pm
If the pully is the 4 bolt type it will work.
Grab the waterpump from toyota (only $120+gst retail :P)
Part number 16100-49846
If your pully is not a 4 bolt type you will need the following pully (2JZ-GTE)
16371-46020
Py7h0n
Postby postfach » Wed Sep 19, 2007 5:55 pm
Py7h0n wrote:If the pully is the 4 bolt type it will work.
16371-46020
I don't think any of the hydraulic fan type water pumps have the 4 bolt pulley, they're all spline with 1 bolt, also it's not just the 4 bolts that matter, the offset of the pulleys are different. in any case, the part numbers listed above are correct. (i think the 2JZ-GTE has a hydraulic fan though? :P a typo perhaps? Maybe you mean 2JZ-GE?)
Oh, and hurry up and get your car going, I can probably drive mine again by the end of the week if I stop being lazy and put that plenum on.
postfach
