2e corolla miss firing?
Postby GDII » Fri Sep 21, 2007 3:03 pm
I bought an ee90 corolla with a 2E carbyd engine 2 years ago.
When you put your foot down it always half stalled but kept driving.
Not long ago I properly sealed up the rocker cover to stop all the oil coming out. Now it wont run very well ova half throttle under load at all rpms. It miss fires or runs short on fuel and I can hear it burning fuel in the exhaust pipe. Nasty bang noises. It still has the same power when its not doing that. It idles fine, starts fine, drives slow fine.
I have replaced the spark plugs, dizzy cap and rottor. They are still fine. Replaced the inline fuel filter in the engine bay as it was very old and full of black paint flake looking things.
Any help would be appreciated as I cant find whats wrong.
GDII
Postby Silent Knight » Fri Sep 21, 2007 3:06 pm
Could be something wrong with the carby if it's just dumping fuel straight out the back...
Silent Knight
Postby GDII » Fri Sep 21, 2007 3:15 pm
Well im not 100% sure what is causing the noise. But i think its that.
I have no idea how my carby works. So many vaccum hoses and wires coming off it. Id get it checked by a mechanic but I dont have the $ and normally I can fix it myself.
GDII
Postby andyztouring » Fri Sep 21, 2007 6:59 pm
Almost sounds like the cam timing is way out,check the camshaft marks,then maybe the ignition timing.
andyztouring
Postby 79rolla » Fri Sep 21, 2007 7:32 pm
i was having problems kinda like this i think if i read corectly...
how old is the fule filter??
mine had a major deaid spot wen the second barrle opend in the carb folowd bu a big backfier then pulled away...
sound kinda fimilier??
i also got new spark plugs at the same time
past: AE82 FXGT
79rolla
Postby Mr Revhead » Fri Sep 21, 2007 11:05 pm
side draught or down draught carb?
so it started as soon as you sealed the rocker cover? check the pcv valve
Postby GDII » Sat Sep 22, 2007 11:38 am
andyztouring, I spose it would be way out. never checked it. engine is a pos lol.
79rolla, Fuel filter might be the original one from 1990. I bought a new one yesterday. Engine hasnt been looked after. Full of dirt and crap.
It does have a dead spot. big dead spot. then it takes off. I practically drive everywhere with my foot down coz its so slow.
I got new plugs awhile ago but it ddnt do any thing. Dizzy cap was stuffed but that ddnt make it better when i changed it. I ges the timing is way out and the carby is stuffed.
Mr Revhead, Its down draught. filter on top and intake pipes at right angles to it. I replaced the rubber gasket 2 years ago to stop the oil coming out but ddnt work. Then a month ago I sealed it with red gasket goo. I think it still has small leaks in it. My brother sprayed wax and grease remover in the PCV valve. But im sure it still works coz when i take the pipe off the valve it stalls. If its stuffed I can get another one but not sure how to get it out. Has a plastic grommet on the rocker cover.
Ill check the timing and see how bad its out.
GDII
Postby GDII » Sat Sep 22, 2007 11:52 am
The timing is @ 15btdc. What should it be and how do i change it?
Do i just adjust the dizzy till its where its meant to be?
GDII
Postby rollaholic » Sat Sep 22, 2007 12:30 pm
is that when its warm? pretty high, should probably be more like 8 or 10. might pay to check timing belt is setup correctly, someone might have dialled in all that advance to try and compensate for the cambelt being a tooth out or something.
Postby GDII » Sat Sep 22, 2007 12:34 pm
I really need to replace the cam belt any way. Was changed @ 125000 and now its 237000 lol. Ill put the timing to 8-10 then see how it drives.
GDII
Postby rollaholic » Sat Sep 22, 2007 12:37 pm
if it makes it worse, i would defintely be looking at cambelt timing
Postby GDII » Sat Sep 22, 2007 12:58 pm
Definitely worse at 10. I still think its fuel related. Cos its burning fuel in the exhaust pipe when its not running properly.
How can I check the cam belt is not in the correct position? Coz i have to take the valve cover off to take the cam belt cover. Really cant be bothered lol. Maybe my spark plugs are not firing properly.
GDII
Postby rollaholic » Sat Sep 22, 2007 1:30 pm
you could check leads and coil, though it doesnt sound like the leads are a problem. ignition system is pretty basic on these, failing that and cambelt timing being ok i think you are either looking for a second hand carb or off to a carb specialist...
i've heard 2Es give problems with carbs sometimes, though i thought it was related to the choke.
Postby GDII » Sat Sep 22, 2007 1:59 pm
Its probably been the carby since i got it. But its good to replace things that are old as its the only car I have and ill keep it for along time. Has no rust and its only the engine and suspension thats stuffed. Gearbox is very good still. Ill figure out whats wrong. Stupid carbyd engines :?
GDII
Postby andyztouring » Sat Sep 22, 2007 2:06 pm
Still think you are going down the wrong road,the fuel will get burnt in the engine if the timing is right.Check the basics before replacing everything.
andyztouring
Postby GDII » Sat Sep 22, 2007 2:19 pm
I dnt intend on buying a new carb. Timing is at 10 and its still drives like it did a few days ago at 15, Very badly. Its driveable when driven slow but when it does crap out its very unpredictable. No matter what rpm its at it still wont go properly. Very uncomfortable ride. It used to hit the flat spot when you put ur foot down but ddnt make the bang in the exhaust. Ill probably try find a new PCV valve and replace the cam belt soon any way just coz it needs that done.
GDII
Postby Mr Revhead » Sat Sep 22, 2007 2:44 pm
why ask for advice if your not prepaired to follow it? :?
Postby GDII » Sat Sep 22, 2007 2:55 pm
Good point :) Well when i get payed next week ill take it to get looked at.
Thanks for all your help guys.
GDII
Postby AE82 FXGT » Sat Sep 22, 2007 9:59 pm
May be a bit late but did you disconnect the vacuum advance when you checked/adjusted the base timing?
AE82 FXGT
Postby GDII » Mon Sep 24, 2007 3:56 pm
AE82 FXGT wrote:May be a bit late but did you disconnect the vacuum advance when you checked/adjusted the base timing?
No. Ddnt touch that. I have played with it ages ago and I know its stuffs with the timing when disconnected. I put the timing to 17 and it goes better. But its sometimes still does it. Owell, Ill get my brother to look at it. Its probly the old carb dying so ill have to find a second hand one for it.
If any one else has any ideas that could help me out then that would be cool.
I just dnt get why it started when I sealed the rocker cover.
GDII
