by AE82 FXGT » Fri Sep 21, 2007 10:40 pm
Easiest way is to keep tension on the belt then crack the bolts off, take tension off the belt and undo them with your fingers.
Reverse for doing them up... just make sure you don't forget.
If you cant be $$% putting the belt back on if you already have it off, loop the belt around the pulley and have someone pull on lightly it to give it tension.
