Noob Question about pulley's
Postby ollieboy » Fri Sep 21, 2007 4:29 pm
If a pulley has four bolts on, how do you get them off? It sounds stupid I know but I just realised I have never done it before and need to.
Cheers guys
Ollie
ollieboy
Postby NOLAW » Fri Sep 21, 2007 5:09 pm
which pulley are you taking off?
NOLAW
Postby ollieboy » Fri Sep 21, 2007 5:13 pm
waterpump pulley on 4age
ollieboy
Postby sergei » Fri Sep 21, 2007 5:15 pm
put the belts on, then you should be able to loosen them with a spanner.
Postby ollieboy » Fri Sep 21, 2007 5:18 pm
ok cheers, i'll have a crack now
ollieboy
Postby AceSniper » Fri Sep 21, 2007 5:54 pm
air tools are your friend :wink:
AceSniper
Postby no_8wire » Fri Sep 21, 2007 6:42 pm
A firm grip and a ratchet? Or lever a pit of wood in so the pully cant spin if your not strong enough...
no_8wire
Postby thegreatestben » Fri Sep 21, 2007 6:46 pm
two spanners?
thegreatestben
Postby bluemaumau » Fri Sep 21, 2007 7:14 pm
i just hold it in one hand and use a long spanner, much easier with belts tho
Postby ollieboy » Fri Sep 21, 2007 8:21 pm
I can't fit a ratchet or two spanners in there.
ollieboy
Postby no_8wire » Fri Sep 21, 2007 8:47 pm
ollieboy wrote:I can't fit a ratchet or two spanners in there.
8O
What on earth is this engine in?
Far out, and I thought the aw11 had a tight engine bay!
no_8wire
Postby Alex B » Fri Sep 21, 2007 8:49 pm
Get a spanner and put in on one side of a nut/bolt and the other end of the spanner on the other side of the next bolt (if that makes sense) so you basically lock the pulley that way, then use another spanner to crack one bolt loose. Turn the pulley around a quarter of a turn and lock it up with the next 2 bolts and crack the next one free etc etc
Postby AE82 FXGT » Fri Sep 21, 2007 10:40 pm
Easiest way is to keep tension on the belt then crack the bolts off, take tension off the belt and undo them with your fingers.
Reverse for doing them up... just make sure you don't forget.
If you cant be $&#$% putting the belt back on if you already have it off, loop the belt around the pulley and have someone pull on lightly it to give it tension.
AE82 FXGT
Postby ollieboy » Fri Sep 21, 2007 10:44 pm
Oh its all sorted guys.
And no_8wire I meant to say I can't fit a ratchet in there and I can't fit two spanners and my hands in there at the same time.
Its an aw11
ollieboy
Postby no_8wire » Sat Sep 22, 2007 4:32 pm
You trying to do this from underneath of from the top? Easier from below...
no_8wire
