GTT Radiator
GTT Radiator
Postby magnazan » Fri Sep 28, 2007 7:39 am
Whilst doing general checks under the bonnet last night i noticed that the 2 grommets at the top where the radiator is clipped into have some play. I can move the whole rad back and forth about 5cms. Just wondering if this is normal??
magnazan
Postby barryogen » Fri Sep 28, 2007 9:28 am
although not a GTT, the one in my runx moves about 1cm total, as in 5mm each way. 5cm doesn't sound right.
barryogen
2ZZ Guru in training
Postby Ae92typeX » Fri Sep 28, 2007 6:59 pm
as above, 5mm sounds fine. 5cm... are the grommets even there?
Ae92typeX
Postby TOYWGN » Fri Oct 05, 2007 6:16 pm
Yep normal as dude.... been in the the radiator game for about 13 years and its pretty normal..and ive got a GTT as well with the same sort of play too :D
1997 Jzx100 Tourer v !!!!
TOYWGN
Postby Ae92typeX » Fri Oct 05, 2007 6:26 pm
TOYWGN wrote:Yep normal as dude.... been in the the radiator game for about 13 years and its pretty normal..and ive got a GTT as well with the same sort of play too :D
surely you mean 5mm is normal (as we suggest above) not 5cm?(as poster suggested)
Im no radiator specalist, but ive never had or worked on a car with 5cm play/movement in a all good setup
Ae92typeX
Users browsing this forum: No registered users and 32 guests
