AE92 GTi Ohm rating
AE92 GTi Ohm rating
Postby FYADUP » Wed Oct 10, 2007 9:26 am
Hey guys.
Whats the Ohm rating for the fuel tank sender in a 1991 AE92 corolla gti hatchback?
Will it be the same even if i go for an aftermarket fuel pump?
Thanks
R.I.P - 90 4AGTE GT-i Corolla Hatch [ROLYOU]
New 91' Corolla GT-i project! WATCH THIS SPACE
FYADUP
Postby FYADUP » Thu Oct 11, 2007 6:13 pm
Someone must know something!
Its not just GT-i im sure its same as other models like the FXGT etc
FYADUP
Postby Zak » Thu Oct 11, 2007 7:52 pm
The resistance changes depending on a full tank or not. Higher resistance is low fuel, low resistance is full fuel. Changing your pump wont affect it.
What are you trying to do with it? Aftermarket gauge?
Zak
Postby FYADUP » Thu Oct 11, 2007 11:43 pm
Because im changing my cauges oveer to autometer and the guy said he needed to know the ohm rating on my fuel tank sender, so he knew which gauge to send me?
FYADUP
Postby Zak » Fri Oct 12, 2007 9:36 pm
Ok, you need to take your gauge out and measure the resistance across it, at each extreme, so low, and high fuel.
They don't have a constant resistance, but rather a range.
Zak
Users browsing this forum: Google [Bot] and 29 guests
