Internal gate capablility?
Postby TRD_ZERO » Wed Oct 10, 2007 6:55 pm
Im wanting to know if my internal wastegate for a evo5 tdo5h will handle 20psi runs reliably? I wont be running that all the time just when i feel like turning it up? Im thinking of not going external and want to know what i could do?
TRD_ZERO
Postby flygt4 » Wed Oct 10, 2007 7:18 pm
not really. you'll probly have issues controlling your pressures accurately. ive seen them ok up to ~17psi on evo's then they start struggling, with lots of spikes. ive seen an evo with a gauge indicated 18psi on a dyno run record spikes of up to 24-25psi. .
best way is to be safe rather than have a big spike and damage a piston or something.
either run less boost or get an external.
flygt4
Postby escortman » Wed Oct 10, 2007 8:28 pm
yeh im only going to run 15psi until i can afford an external
4x4 toyota blizzard offroader
escortman
Postby MRDRFT » Sat Oct 20, 2007 9:21 pm
or port out or internal a lil and weld a bigger plate on the gate and put a bigger spring in it!thats all i did!worked a treat
1992 toyota supra 1JZ power
210kw atw on 12psi
1999 nissan silvia drift car,
223kw atw on 12psi
MRDRFT
Postby method » Sun Oct 21, 2007 3:03 pm
My evo managed to hold 20psi fine, but it would drop off to about 17psi at higher rpm. Did runs at torque performance to verify this.
Its easily solved with a after market wastegate actuator. Cheaper than a external and you can get 18psi ones for the td05's.
PICS UPDATED DAILY
method
Postby escortman » Sun Oct 21, 2007 6:26 pm
wat about the 16g tdo5 with adjustable actuator? does any1 have any feedback about these
escortman
