1jzgte coil packs
1jzgte coil packs
Postby MRDRFT » Mon Oct 22, 2007 8:13 pm
how much HP can the factory coil packs hold before needing to be upgraded or wont i need to?
also what brand fuel pump do you recomend to get to pump the juice to the 1jz?
thanks
1992 toyota supra 1JZ power
210kw atw on 12psi
1999 nissan silvia drift car,
223kw atw on 12psi
MRDRFT
Postby 92GTApex » Mon Oct 22, 2007 9:06 pm
Depends on the condition of them, if there running fine now they should handle plenty.
I know of stock coilpacks that were cracked then glued up supporting well over 400rwkw
Logan
Current ride: 92 Levin GT Apex
Current project: 91 Levin GT Apex (Crashed - It wasnt me)
www.area-51.co.nz
www.toyperformance.org.nz
www.lextreme.com
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1731
92GTApex
Postby sergei » Mon Oct 22, 2007 10:41 pm
I don't see how power will damage the coil packs.
From coil pack point of view power is irrelevant - it is there to spark not to push pistons ;). Obviously there is the compression which might effect the spark but that is another issue completely.
Postby mjrstar » Fri Oct 26, 2007 2:06 pm
sergei wrote:I don't see how power will damage the coil packs.
it's the other way around!!! the coil packs can damage the top end power.
this would probably be around the 400kw mark as mentioned above.
I see nyle Buckley has upgraded the coils in jos drag corona , he used to have a set of diamante v6 coil packs but has since swapped out to 6 bosch individual coil packs.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby postfach » Fri Oct 26, 2007 6:36 pm
how much power does john (audi man) make now? last time i checked it was something in the order of 450rwkw, and that's using stock coil packs with epoxy. as for fuel pump, get whatever your heart desires, i've been through 3 bosch pumps, they worked great till they broke (which can be embarrassing if you're trying to do a ¼ mile) , now i'm using a walbro, and its fine too.
postfach
Postby Py7h0n » Mon Oct 29, 2007 5:12 pm
Stock packs in good condition can take over 1000hp as the yanks have prooven many times.
I know of several people with >400wkw and no ignition system changes.
Py7h0n
Postby 92GTApex » Mon Nov 05, 2007 7:05 pm
He was making 488rwkw a while ago, but hes upgraded since then
Think hes changed to a better condition set of coilpacks, as I have a couple of his old ones.
He made the 488 on his worst 6 coil[acks that he glued up for an experiment to see how well it worked
Logan
www.area-51.co.nz
www.lextreme.com
92GTApex
Postby MrOizo » Tue Nov 06, 2007 10:43 am
92GTApex wrote:He made the 488 on his worst 6 coil[acks that he glued up for an experiment to see how well it worked
Logan
So the gluing them up worked? were the sparks 'leaking'? I've heard some use epoxy glue or some shhit
MrOizo
Toyspeed Legend
Postby Silent Knight » Tue Nov 06, 2007 11:01 am
Yep, get them nice and dry an use epoxy on them. You could also use a thin, very high temp resistant heat wrap around them after glue to be sure...
Silent Knight
Postby 92GTApex » Sat Nov 10, 2007 5:47 pm
I used epoxy resin on the set in mine which were making the car miss like a pig even without load/boost (had no intercooler piping hooked up
Glued them up, and pulled top gear in the driveway on the spot :)
no misses at all
Logan
www.area-51.co.nz
www.lextreme.com
92GTApex
