how much HP can the factory coil packs hold before needing to be upgraded or wont i need to?
also what brand fuel pump do you recomend to get to pump the juice to the 1jz?
thanks
sergei wrote:I don't see how power will damage the coil packs.
From coil pack point of view power is irrelevant - it is there to spark not to push pistons. Obviously there is the compression which might effect the spark but that is another issue completely.
92GTApex wrote:He made the 488 on his worst 6 coil[acks that he glued up for an experiment to see how well it worked
Logan
