Wasted Spark??
Wasted Spark??
Postby TRD_ZERO » Thu Nov 08, 2007 7:27 pm
Well i was just wondering what is wasted spark? What are their benefits from running over a dizzy if any? Do you need an aftermarket comp to run one if so what else is needed to convert drom dizzy to wasted spark on a 20v. Thanks just curious as it seems interesting.
TRD_ZERO
Postby Zak » Thu Nov 08, 2007 7:37 pm
Wouldn't even bother, need a new ecu (unless your very electronicly minded) and you'll get pretty much no benefits other than not having to replace your rotor and cap any more.
Zak
Postby Crucible » Thu Nov 08, 2007 7:48 pm
wasted spark fires two cylinders at once, or two cylinders on the same crank plain. One cylinder is on comp/power and the other exh/inlet.
so for a 4 cylinder it will be 1-4 and 2-3, on a 6 cylinder (inline) 1-6, 2-5, 3-4. Because two coils are doing the work compared to one on a dist setup, the main advantage would be dwell time.
Crucible
Real Life Mechanic
