ae111 blacktop missing???
Postby devius » Fri Nov 30, 2007 5:40 pm
i have a 1996 ae111 blacktop 4age levin
i am having missing issues, not all the time but enough to be annoying,
start accelerating and then put my foot dont and it misses/hessitates and then takes off.
about 2-3 months ago i replaced the spark plugs and rocker cover gasket.
about 2 weeks ago i got an oil catch can fitted.
about a week ago i got my cat removed and a new apexi n1 end muffler put on.
any thoughts?
devius
Postby CAMB01 » Fri Nov 30, 2007 5:50 pm
Leads?
Dizzy cap?
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby rollaholic » Fri Nov 30, 2007 6:00 pm
when did it start missing?
Postby devius » Fri Nov 30, 2007 6:36 pm
cam - leads and dizzy look good
rollaholic - about 4 days ago
devius
Postby CAMB01 » Fri Nov 30, 2007 6:38 pm
check the resistance of the leads.
I had the same problem with my old 4age, replaced the cap and leads and was sweet.
I'm not saying thats the problem with yours but could be a possibility.
CAMB01
Postby devius » Fri Nov 30, 2007 6:47 pm
my mechanic had a quick look and play and said leads, plugs, dizzy and rotor?? seem fine but id have to bring my car in on a day he was free to find the problem
devius
Postby gepsk8 » Fri Nov 30, 2007 7:19 pm
just get the car running and fit each lead up about half way up spark plug hole, it should run same on bad 1 and ruff as guts on gud 1's, say u lead are passed the use by date tho.
O272754663
gepsk8
Postby B1NZ » Sat Dec 01, 2007 6:59 am
sounds like it could be the TPS?
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby devius » Sat Dec 01, 2007 10:50 am
damn you get up early B1NZ lol
ya reckon it could be tps?
devius
Postby devius » Sat Dec 01, 2007 11:47 am
ran a diagnosis and came back with no faults
devius
Postby Distrb » Sat Dec 01, 2007 10:05 pm
I got a couple of sets of leads and a new dizzy cap you can borrow to try out aaron
Distrb
Regular Poster
Postby devius » Sat Dec 01, 2007 11:58 pm
oh real, cheers andrew that would be good man
devius
Postby Cakky » Sun Dec 02, 2007 11:25 am
are your battery terminals on tight?? simple but noticed this on my blacktop the other day, seems smoother now
1989 Corolla GT sedan blacktop 20v
Cakky
Postby malc » Sun Dec 02, 2007 12:12 pm
is the hesitation always in the same rev range? or does it happen what ever revs you are doing at the time?
malc
Postby devius » Sun Dec 02, 2007 2:35 pm
Cakky- will check battery
Razz- normally down low rev range and sometimes up high
devius
Users browsing this forum: Bing [Bot] and 8 guests
