Silvertop in AW11 suddenly wont start
Postby cogent » Mon Dec 03, 2007 12:45 pm
ok this has me a bit stumped.
got my flywheel all tightened up on saturday, installed the clutchpack and bolted the gearbox on and mounted up in the engine bay. then on sunday i did the driveshafts, clutch slave cyl, shifter arms, plenum etc etc.
turned the key, fired right up to an idle of 1000rpm. chucked the wheels back on, dropped it on the floor and started again no worries and backed out of garage. checked water, needed to be topped up. stopped/started it around 9/10 times over the course of half an hour with no problems at all.
got the water topped up, went to put the air filter back on, wrangled with it a little (tight fit with the AFM in the way) and then it stopped starting. just cranks over and doesnt catch.
i checked all the connections around where the air filter sits in case i knocked something loose but everything is fine.
fuel pump whirrs when you have the car set to 'on' and push the AFM flap, so i presume its getting fuel
the sparkplugs are fine, not fouled or anything and spark when cranking, so i presume its getting spark
i pulled the plenum etc out and theres nothing blocking anything, so i presume its getting air
I swapped out the ignitor module with no luck, same with AFM. unplugged IAC-V, WTS, TPS and knock sensor one at a time and still no luck. Cranking speed is good, tacho registers about 500ish RPM at crank, voltage is good. starter lead is bolted down good and hard, grounding is good. AFM plugged in. cambelt still in one peice.
I cannot crash start it either.
got me stumped.
the wiring is proven to be working as far as i know, as this is the second silvertop i have had in this car (first one spun a bearing) and the car fired right up earlier also. just stopped starting!
edit: oh and the alarm/immobiliser has been disabled everytime i've tryed to start it.
cogent
Postby neo » Mon Dec 03, 2007 12:56 pm
Ok something really simple, but in the same area (well in my car anyway), checked the EFI fuse in the engine bay? (however this would stop the fuel pump anyhow)..
The sensor plug hasn't come off the distributor?
neo
Postby cogent » Mon Dec 03, 2007 1:00 pm
neo wrote:The sensor plug hasn't come off the distributor?
f.ck i bet thats the one, i only checked spark at the coilpack/ignitor thing...the one with the kinglead that goes to the dizzy.
cogent
Postby cogent » Mon Dec 03, 2007 7:16 pm
ok dizzy is plugged in properly, all 4 sparkplugs getting spark aswell.
also checked that alarm isnt playing buggery, used the bypass code supplied with the alarm with no luck.
confirmed that fuel is coming out the return line, also have checked for loosewires/unplugged stuff but found nothing yet.
interestingly, if you 'arm' the alarm, it cranks exactly the same way as when 'unarmed'.
cogent
Postby AceSniper » Mon Dec 03, 2007 7:32 pm
ecu codes?
AceSniper
Postby cogent » Mon Dec 03, 2007 7:43 pm
stay tuned...
cogent
Postby Skin » Mon Dec 03, 2007 8:05 pm
stick to the rotaries :P
cogent wrote:iPhones can eat a dick.
1981 Mazda RX7
1997 Toyota Corolla
Skin
Postby Leon » Mon Dec 03, 2007 8:32 pm
efi fuse?
Postby Mr Revhead » Mon Dec 03, 2007 8:43 pm
Skin wrote:stick to the rotaries :P
stfu you!
alarm.... hehehe muppet :lol:
triple checked the AFM plugs etc?
Postby cogent » Mon Dec 03, 2007 8:53 pm
codes 12 and 14, which point to ecu, ignitor, distributer and a short in the wiring somewhere.
we have also determined there is no spark.
hm.
cogent
Postby g-lo » Mon Dec 03, 2007 10:28 pm
take the top cambelt cover off
and check the belt turns while cranking
g-lo
Postby Adamal » Mon Dec 03, 2007 10:36 pm
Maybe its just trying to 'fit in' with being in an AW?
Postby cogent » Mon Dec 03, 2007 11:00 pm
yeah cambelt is turning and is in one peice aswell.
hmm you're right adamal. maybe i should get an sw20 instead. Surely I could drive it more than the aw11, after I get it back from the panelbeaters a year later with its widebody kit that is :P
cogent
Postby Adamal » Mon Dec 03, 2007 11:19 pm
Now now, no need to get nasty :P
I, too, know the pain of having an AW that can't get a WOF because its got rust in places which they consider "structural" (A and B pillar. Pfft. SIF!) and kinda regret taking it to get a legit WOF!
One day I'll have at least one, perhaps both back on the road :P
As for yours, the only thing you changed was the clutch and you'd done nothing else electrical...
By the sounds of it, it could be your alarm, if it does the same thing when armed. How well do you know the unit? Could be a relay issue. Could try to temporarily wire it out of the equation?
If it were a buggered relay, that may explain why the bypass code wouldn't work.
Postby Nuty|Mike » Tue Dec 04, 2007 9:06 pm
i had similar problems with my 20v aw ended up needing to earth the ignitor properly. try your earths ?
05 Mazda Verisa .....for the Family
Nuty|Mike
Postby cogent » Fri Dec 07, 2007 11:38 am
ignitor grounded straight to battery to be sure.
still no luck with this! we thought the dizzy was faulty but now we have plugged the ignitor in ( :lol: ) we have managed to get consistant spark at all 4 plugs.
wonder if a wire in the loom broke :( hope not.
cogent
Getting wet ??
Postby jondee86 » Fri Dec 07, 2007 8:08 pm
Seem to remember someone else had a similar problem, and it
turned out to be that the common injecter earth had not been bolted
down to the head (or wherever it bolts to). There was fuel to the rail
but the injectors weren't firing.
Do the plugs get wet after you have cranked it ?? Can you feel or
hear the injectors firing ??
Hey... worth a mention :)
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby Adamal » Fri Dec 07, 2007 11:42 pm
If you take the plugs out, can you shine a torch down there and see if you've got fuel in there?
Postby cogent » Sat Dec 08, 2007 3:23 pm
at this stage i wonder if its a wiring fault, start signal not intact or something.
ill definantly check the fuel grounds, but it smells of fuel after cranking, and with the sparkplug out it shoots puffs of fuel out the hole.
will update thread tomorrow with my findings as im a bit busy today :lol:
btw, anyone wanna buy a silvertop AW11 :lol: :lol:
cogent
Postby 79rolla » Sat Dec 08, 2007 5:03 pm
Adamal wrote:If you take the plugs out, can you shine a torch down there and see if you've got fuel in there?
and if you dont have a torch you can use a lighter :wink:
try engin start and see what happens...
also is there a chance you damaged AFM?
past: AE82 FXGT
79rolla
Users browsing this forum: Google [Bot] and 20 guests
