Cam lobe separation...
Postby jondee86 » Thu Jan 03, 2008 7:47 pm
Does anyone know what the lobe separation is supposed to be
on a stock 4AGE smallport with OEM cams ??
I have adjustable pulleys without markings, and I would like to
start off by degreeing the cams to stock specifications. Searching
brings up squat, except that it will be somewhere between 100-100
and 110-110 :?
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby ChaosAD » Fri Jan 04, 2008 9:44 pm
I think it says on the cam spec page on the tech section of club4ag.com
ChaosAD
Cam timing...
Postby jondee86 » Sat Jan 05, 2008 10:13 am
Yeah, I saw that they say 111-111 for stock cams, but then it goes
on to say that good power has been found at 100-100 8O
This is a huge variation, and I seriously doubt if both figures can be
correct. So unless I can find another reference, I will have to put some
stock pulleys back on, and measure my own cams.
Cheers... jondee86
jondee86
Postby ChaosAD » Sat Jan 05, 2008 11:38 am
Had a look and for the 232's it only says the opening timings.
for the bluetop (Stock -max lift @ 111°) for intake and exhaust.
it says that some people have altered them to 100-100, which is a lot of overlap, I doubt the stock ecu would like it.
Id set it to 111-111 and then have a play round on the dyno.
Probably not much to be gained though without sacrificing other parts of the powerband
ChaosAD
Just in case you were wondering :))
Postby jondee86 » Tue Feb 05, 2008 8:59 pm
In the absence of a more authoritive number, I set the cam lobe
C/L's at 110-110 to provide a convenient baseline. They had been
running at 112.5 intake and 108 exhaust. The difference was barely
noticeable... runs a tiny bit smoother and quieter, so I guess I might
have lost a hp or two :-|
I also measured the duration for the "232 degree" cams :
Duration @ 0.006" lift = 232 degrees
Duration @ 0.050" lift = 192 degrees
Total lift = 0.280" (7.11 mm)
Could be useful if you are wanting to compare with aftermarket cams.
Cheers... jondee86
jondee86
