Problems with hot water
Postby tsoob » Fri Jan 04, 2008 1:34 am
I have been running around the rolla for about 10 days now, it is going well, the ecu needs to be mapped properly, (is on the base map) we have taken some fuel out of the map to compensate for the bigger fuel system, all the wiring has been finished and put away and car is driving nice. when i was away ( went up north) had nice drives up there spend $235 in gas for the 6 days and did bugger all driving while i was there (one dairy trip) and back to home. motor has got nearly 1000ks on it now was fresh rings and mian bearings. I have noticed the cooling system needs some attention, it is ok when you are driving 60ks+ (86-88degrees) really good at 100ks+ (80- 84) and lower at night. When we go in the day it sits about the same until we go slow 20-40ks will get to 98+ i took it through one drive thru and it got really hot (99+) but cooled back down as soon as i drive away. What soultions would work for my setup? (wrap, beanie ??)
Nick
tsoob
Re: Problems with hot water
Postby Lloyd » Fri Jan 04, 2008 7:29 am
tsoob wrote:What soultions would work for my setup?
You setup being...?
Postby tsoob » Fri Jan 04, 2008 11:30 am
fwd 4agte like barry, brendon etc.
tsoob
Postby Crucible » Fri Jan 04, 2008 9:29 pm
are your fans cycling? yep?
Crucible
Real Life Mechanic
Postby 85AW20v » Fri Jan 04, 2008 11:11 pm
Get your radiator cleaned out properly by a shop. Sounds like there's enough airflow at speed to keep it cool but not enough airflow at slow speeds. It'll probably get worse the harder you drive it as well. Just tooling around the place it'll be fine.
See ya
Simon
85 MR2 20v
85AW20v
Postby AE82 FXGT » Sat Jan 05, 2008 6:48 pm
Simon85MR220v wrote:Get your radiator cleaned out properly by a shop. Sounds like there's enough airflow at speed to keep it cool but not enough airflow at slow speeds. It'll probably get worse the harder you drive it as well. Just tooling around the place it'll be fine.
Yep, same thing happened to me. Just take it out and give it to a radiator specialist, only cost like $30 and they will take the tanks off, flush it, and clean the core out.
AE82 FXGT
Postby tsoob » Sun Jan 06, 2008 9:39 am
its a brand new radiatior, fan is run of the ignition so is always on, if i stop the car it heat soaks and inlet temps get up to 50 degrees.
tsoob
Postby tsoob » Sun Jan 06, 2008 12:53 pm
i just saw a mate and he reckons the fan is going the wrong way, will change and update later
tsoob
Postby Adydas » Sun Jan 06, 2008 1:06 pm
can you update your "location" for us as well, i dont think anyone would agree the word "fuc****" needs to be in there.
Adydas
Postby tsoob » Sun Jan 06, 2008 2:00 pm
yes i did the other day but it has reverted back sorry.
tsoob
Users browsing this forum: Google [Bot] and 20 guests
