20v stalling + engine light
Postby RickGT » Tue Feb 05, 2008 7:19 pm
car is a ae101 levin, motor runs perfect except sometimes it just stalls and is hard to start, dont think it is fuel as you can smell it when you try to start it, hooked up a timing light an started it an light was cuttin out at same time engine was splutering, so i think it is the coil and or ignitor, anyone else had this problem?
thanks
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Postby Paulio » Wed Feb 06, 2008 9:46 pm
not me. does it stall/cut out when ur driving or or is it just when you come to a stop?
paul
Paulio
Postby gmacrae » Fri Feb 08, 2008 11:59 am
i just had an ae101 coil die on me, try replacing that. Same as 1uz-fe coils.
gmacrae
Postby RickGT » Sat Feb 09, 2008 9:59 am
yea i just stalls whenever, engine light comes up then dies
EP91 Glanza V
RickGT
Postby Paulio » Sat Feb 09, 2008 10:22 am
plugs and/or coil?
just had a weird problem in a mates ae101, ran for a couple of minutes then just died and wouldnt start for another 5-10 mins each time, diagnosed the shit out of it (had no spark) and ended up using the secondary wires off the link ignitor to the coil, cleaned the plugs and voila!
have you gone through the basics, eg checked spark and fuel flow?
paul
Paulio
Postby Paulio » Sat Feb 09, 2008 10:25 am
(failing that, i've got a spare ignitor and coil you could borrow if need be)
Paulio
Postby RickGT » Sat Feb 09, 2008 10:26 am
yea tried to put in diag mode but check lt never flashed, i dont think it is the plugs because i had the timing light on the lead from the coil and it was missing, would it be more likely the coil or the ignitor?
EP91 Glanza V
RickGT
Postby Paulio » Sat Feb 09, 2008 10:32 am
may be but just for shits and giggles, check the earthing. problem is im sure the engine check light shouldn't come on if its just a coil or ignitor gone wrong.
you sure its not a miss-fire?
Paulio
Postby RickGT » Sat Feb 09, 2008 10:36 am
yea sure its not a miss fire, yea ill look at that too
thanks
EP91 Glanza V
RickGT
Postby RickGT » Mon Feb 11, 2008 4:59 pm
well it is now running fine, but the engine light is constantly on, but does flicker now and then (not flashing)
i tried to run error codes but when e1 and te1 are bridged the engine light does not even flash at all
any ideas
EP91 Glanza V
RickGT
Postby piw » Mon Feb 11, 2008 6:05 pm
Stuffed ECU, Common on ae101's.
piw
Postby RickGT » Mon Feb 11, 2008 7:29 pm
yea that was the next thing i was going to check
EP91 Glanza V
RickGT
Postby Tru3no20v » Mon Feb 11, 2008 8:38 pm
"hey ben im goin to grab ur 20v ecu, cheers." haha cant get u dwn hea wen he in auckland!
ae82 fxgt corolla
<<<-------- . . . the names old
Tru3no20v
Postby RickGT » Mon Feb 11, 2008 8:57 pm
ban "Tru3no20v"s avatar, thats stealing!
it was mine first you h**o
EP91 Glanza V
RickGT
Users browsing this forum: Google [Bot] and 29 guests
