what to take off a b/top to use on a s/top 20v
Postby hsmidy » Thu Feb 14, 2008 5:34 pm
hey
so i managed to score myself a pretty cheap blacktop engine,loom and ecu, only really brought it to use the vvt pulley as my one is stuffed,
now i have heard that the black tops are a better engine but what can be taken off them to be used on a silvertop(for some kind of gain), i dont really want to swap the whole engine over as my silvertop has only been rebuilt about 30,xxxkm's ago.
hsmidy
Postby rollaholic » Thu Feb 14, 2008 5:50 pm
transplant, blacktops are a pretty serious revision over the ST.
personally i dont think you would regret it.
Postby hsmidy » Thu Feb 14, 2008 5:55 pm
yeah but like i said i just dont really want to have to pull out my near new silvertop for a blacktop will 120,000kms on it,
plus the engine used to be on an auto and my car is a manual, do the manual flywheels bolt straight up to the crank(it looks like it would )?
and i pressume the silvertop trans bolt up all good too?
hsmidy
Postby 78ke30 » Thu Feb 14, 2008 5:57 pm
Previously owned: 1980 1275 gt mini clubman, 1979 mini clubman, 1980 ford escort, 1978 toyota corolla ke30
Current AE111 levin BZR
78ke30
Postby 78ke30 » Thu Feb 14, 2008 6:03 pm
You could always swap over the head including ITB and exhaust manifold if you have them.
78ke30
Postby hsmidy » Thu Feb 14, 2008 6:07 pm
yeah i looked throught there but just wanted to make sure what parts were actually able to be swaped over between engines.
with swaping the heads over would i have to run the blacktop ecu?map sensor etc?
hsmidy
Postby Cakky » Thu Feb 14, 2008 6:14 pm
swap the looms and ecu over, I think acesniper did this and got good results
1989 Corolla GT sedan blacktop 20v
Cakky
Postby 78ke30 » Thu Feb 14, 2008 6:16 pm
I don't see why you would have to change to blacktop ecu
Have seen blacktop conversions running silvertop ecu and loom( with AFM)
78ke30
Postby Crampy » Thu Feb 14, 2008 6:18 pm
Swap the head and loom and ECU. The Silvertop bottom end is better (conrods) but heavier.
The Blacktop head is better and with the head and the ECU and sensors, you can get rid of the AFM and run some aftermarket trumpets (properly boxed and with a good air feed fo course)
Crampy
Postby ChaosAD » Thu Feb 14, 2008 6:28 pm
There was a guy on here that swapped the complete blacktop top end onto a silvertop. I think he posted dyno plots even.
ChaosAD
Postby hsmidy » Thu Feb 14, 2008 6:30 pm
ok so the general consensuse is run the black top head with loom and ecu,
are there any bits involved in this convesion that might catch me out?
obviously ill have to wire in a switch for the pack/neutral switch because of the auto loom, is there anything else?
hsmidy
Postby neo » Thu Feb 14, 2008 6:41 pm
hsmidy wrote:are there any bits involved in this convesion that might catch me out?
yip the rest of us coming down on a road trip and taking all the backtop goodness off you hands before you get a chance to put it in 8)
neo
Postby bluemaumau » Thu Feb 14, 2008 7:06 pm
i didnt read nay of the above but id say put evwerything blacktop on your silvertop block 8) near blacktop but no rod vs block action (hopefully)
Postby hsmidy » Thu Feb 14, 2008 7:46 pm
hey can anyone comfirm that the blacktop and silvertop head gaskets are the same?
hsmidy
Postby ChaosAD » Thu Feb 14, 2008 8:15 pm
ChaosAD
Postby hsmidy » Thu Feb 14, 2008 8:37 pm
hey thanks for finding that post, well by the sounds of it (and not seeing those dyno results) theres not really that much to be gained by swaping heads, just a little in the upper end.
hsmidy
Postby AceSniper » Fri Feb 15, 2008 4:26 pm
leave the silvertop bottom... this means you keep using the silvertop cambelt.
Blacktop head.. get it surfaced, light skim .2-.4mm
TRD .8mm heady
Blacktop TB's, headers, cams...
wouldnt bother with the hassle of blacktop ecu. Silvertop one will run it just make sure you seal the plenum up air tight... the bottom dosnt like to seal.
I ran s/t ecu/loom on my blacktop went well. The only other thing you may want is the blacktop pistons but why bother if you have rebuilt it... the TRD heady and a light skim will get you 11-11.2:1
AceSniper
