Harley
gleem wrote:its just hanging atm. havent given it too much thought trying to fix rattling noises atm.. whats the idea thing to do with it?
sleepy wrote:Hi gleem, what did you do with the air temp sensor, did you plumb it back into the piping of your pod intake? or did you just leave it hanging near the pod filter?
strx7 wrote:sleepy wrote:Hi gleem, what did you do with the air temp sensor, did you plumb it back into the piping of your pod intake? or did you just leave it hanging near the pod filter?
the std air temp sensor for the efi system is located in the plemum chamber of the inlet manifold, has a 3 pin plug from memory
