Truenotch wrote:kyb's will be stiffer, but aren't made to be used with low springs normally. Same as any other stock shock, if you go really low they will need to be shortened to keep the spring captive.
grantourismo wrote:Truenotch wrote:kyb's will be stiffer, but aren't made to be used with low springs normally. Same as any other stock shock, if you go really low they will need to be shortened to keep the spring captive.
u mean shorten the shock absorbers ? how is that done @_@?
what if i am just going for 20mm lowered would that cause a big issue ?
2LTR Rona wrote:BZG|Bling- How do you know grantourismo HASN'T already done that? Chances are you dontNot everyone is as all knowledgeable as yourself
Mr Revhead wrote:and king springs.... i would look at TEIN
i am not a fan of king springs.
2LTR Rona wrote:grantourismo wrote:Truenotch wrote:kyb's will be stiffer, but aren't made to be used with low springs normally. Same as any other stock shock, if you go really low they will need to be shortened to keep the spring captive.
if you are looking at a 20mm drop you will probably not have to worry about gettng the shocks shortened. in my personal experiance I didnt need to.
With King springs (assuming you are not using super low) you will probably find a drop of around 40mm is more likely, once again in my experiance shocks did not have to be shortend
what car are you looking at putting this setup in to ?
As grantourismo has said, what you read on a site can "sometimes" be rather different to how it performs, everyone needs to start somewhere eh
