RWD 20v 4age waterlines
Postby rollas22 » Tue Mar 11, 2008 8:54 pm
Just about to start my RWD 20v 4age turbo in my KE35 coupe...
just wondering what other ppl have done when it comes to the waterlines... as they come from the rear of the motor.
Was thinking of havin them run back round an under the quads an both go to the 1 side rather than go near the exhaust an turbo etc...
Let me know any other options
KE-Corolla's for life!!!
rollas22
Postby Trls250s » Wed Mar 12, 2008 10:33 am
http://www.rollaclub.com/board/index.ph ... opic=14024
All you need to know on how to rwd that 20v.
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby Mr Revhead » Wed Mar 12, 2008 12:50 pm
that method reverses the flow through the engine
so the inlet ports get the hottest water
instead of the stock system of inlet getting coolest flow first
Postby rollas22 » Wed Mar 12, 2008 6:30 pm
[quote="Trls250s"]http://www.rollaclub.com/board/index.php?showtopic=14024
All you need to know on how to rwd that 20v.[/quote]
Thanks heaps guys!!!
rollas22
Postby lorolla24 » Wed Mar 12, 2008 8:01 pm
I've just done the same conversion except i have made a plate for the back of the head and welded two tubes that line up with the hole's in the head and then run an external thermostat from a 4AGZE. This way you will retain the correct flow.(cooler water though the inlet first)And you retain the original water pump and housing.
Its is a bit of mucking around but so is the other way.
[/img]
Ke35 20v turbo - 200kw atw 13psi
13.5@169km
lorolla24
Postby Trls250s » Wed Mar 12, 2008 10:08 pm
Yea both methods are a bit of a muck around, but 20vs were never ment to go into rwd's.
1600cc of Awesome
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby stalker » Thu Mar 13, 2008 12:35 am
Heres what mine looks like...not my doing, I just brought it like this. :lol:
Prob not the best if there is going to be a nice turbo sitting under it, but gives you a visual aid...lol
AE85.6 Levin - Project car Click Here
RZ Supra formully known as EMZ RZ
stalker
