Please Confirm these Sensors (4agze aw11)
Postby Calvin » Mon Mar 17, 2008 11:28 pm
Just need confirmation as to whether this is correct. found it on the net. thanks
Calvin
Postby Pelo » Tue Mar 18, 2008 3:17 pm
Yes look right to me. The fan switch is for the side vent fan not the radiator fan though.
Pelo
Postby Calvin » Tue Mar 18, 2008 3:26 pm
Pelo wrote:Yes look right to me. The fan switch is for the side vent fan not the radiator fan though.
Yeh for the aw11 only eh.
Anyone think this is wrong??
Reason i ask is because some posted this on MR2OC in reply to the above picture
all of the color codes on the sensors were the same (green top leads to cold start injector and the starter... i remember that and it seemed strange, brown is the only one that leads to the ecu....
Is this dude wrong?
Calvin
Postby matt dunn » Tue Mar 18, 2008 11:33 pm
yes, green is definatly ECT sensor,
and brown is definatly the Thermo-time sw for cold start injector.
The only one i'd say you have wrong in the pic is labelled
EFI water temp switch,
which is normally not there on most 4age,
so would say that is the MR2 side fan?
Postby Calvin » Wed Mar 19, 2008 11:10 pm
From memory its something related to the aircon? .. the sensor on the exh/gearbox side of block , which shares the same bolt as the engine hook, activates the mr2 side fan
Calvin
Users browsing this forum: Bing [Bot], Google [Bot], Yahoo [Bot] and 42 guests
