Pelo wrote:Yes look right to me. The fan switch is for the side vent fan not the radiator fan though.
all of the color codes on the sensors were the same (green top leads to cold start injector and the starter... i remember that and it seemed strange, brown is the only one that leads to the ecu....
matt dunn wrote:
The only one i'd say you have wrong in the pic is labelled
EFI water temp switch,
which is normally not there on most 4age,
so would say that is the MR2 side fan?
