Is this diff and LSD?
Postby cat007 » Sun Mar 23, 2008 9:00 pm
Hey all
From a Supra:
The first picture explains where the 2nd picture is taken from:
And here's a full view of the diff:
Cheers :)
Postby QikStarlie » Sun Mar 23, 2008 10:47 pm
yes it is
QikStarlie
Postby cat007 » Sun Mar 23, 2008 11:06 pm
Here's hoping :)
Postby QikStarlie » Mon Mar 24, 2008 10:04 am
could be a hilux style one though. ie no ramps. just big preload spring. thats what i found when i pulled my supra one apart.
defintly a clutch plate you can see, in the shot through that hole
QikStarlie
Postby AE25 » Wed Mar 26, 2008 11:44 pm
looks very similar to a hilux lsd. but the casing is not exactly the same.
can you see through the centre of it where the axles slide into?
the hilux head i had.. you couldn't, as the spring retainer was solid.
E2 & E7 fanatic
http://www.toycrazy.net
AE25
