Is this diff and LSD?
Postby cat007 » Sun Mar 23, 2008 9:00 pm
Hey all
From a Supra:
The first picture explains where the 2nd picture is taken from:
And here's a full view of the diff:
Cheers :)
Postby QikStarlie » Sun Mar 23, 2008 10:47 pm
yes it is
QikStarlie
Postby cat007 » Sun Mar 23, 2008 11:06 pm
Here's hoping :)
Postby QikStarlie » Mon Mar 24, 2008 10:04 am
could be a hilux style one though. ie no ramps. just big preload spring. thats what i found when i pulled my supra one apart.
defintly a clutch plate you can see, in the shot through that hole
QikStarlie
Postby AE25 » Wed Mar 26, 2008 11:44 pm
looks very similar to a hilux lsd. but the casing is not exactly the same.
can you see through the centre of it where the axles slide into?
the hilux head i had.. you couldn't, as the spring retainer was solid.
E2 & E7 fanatic
'71 ke26 '75 KE25 SR 4AGE '78 bug KP60 '83 KE70 SR Coupe 3TGTE '84 ke74 '84 ae85.6 trueno '84 YN57 SR5 '86 AE82 FXGT 20v '91 ST185 '92 SW20
http://www.toycrazy.net
AE25
