Requirements for a cert
Postby fuzzilogyc » Tue Apr 01, 2008 3:54 pm
Looking at getting a cert for my coilovers and wondering if i need WOFable tires. If they do, i guess i should get some new tires before taking it down...
How does it work? Do they only check what you are getting certed? How long does the inspection usually take?
fuzzilogyc
Postby IH8TEC » Tue Apr 01, 2008 3:57 pm
yes you will need good tires. as for how long, depends who you go to and how much your getting done. just coilovers shouldn't take too long..
Postby no_8wire » Tue Apr 01, 2008 4:43 pm
Went I had my bigger brakes, engine transplant, suspension cert took about 30min? For the inspection, and about a week for the legal documentation etc...
no_8wire
Postby the fallen303 » Tue Apr 01, 2008 6:01 pm
i just had my rolla liftback in for certing for it's conversion, they noted everything, the momo steering wheel on a bosskit, the levin front seats, the factory 14*6 steelies, the front subframe, lowering springs, brakes, oh yeah, and the change of engine. it's basically a wof with a fine tooth comb, and if anythings not standard, but is safe, they note it on the plate. if you fail the cert though, you gotta pay to get it rechecked, so best to go over it beforehand to make sure they don't ping you on anything.
true house of JZ
Stay true to the origin
the fallen303
Postby fuzzilogyc » Tue Apr 01, 2008 6:06 pm
pay for recheck? 8O
thats not what i gathered from searching the posts on this forum. i read that the certifier just gives you a list of stuff to do (if anything), you go and do it, then he checks it off...
fuzzilogyc
Postby IH8TEC » Tue Apr 01, 2008 6:36 pm
same here, believe if a re-check is required it's included in the cost.
Postby GTCRSHR » Tue Apr 01, 2008 6:40 pm
the fallen303 wrote: if you fail the cert though, you gotta pay to get it rechecked, so best to go over it beforehand to make sure they don't ping you on anything.
looks like you got ripped then,
my re test was free, every one i know who had to go back was free
Nothing to see here ...
GTCRSHR
Postby deaf_rattle » Tue Apr 01, 2008 7:34 pm
you have 2 months to sort out any issues before you need to pay again.
Postby l1ttle_d3vil » Tue Apr 01, 2008 7:45 pm
GTCRSHR wrote:my re test was free, every one i know who had to go back was free
2nded. it wasnt a full retest, just checking the stuff which failed... it took him about 10 seconds to do my recheck...
Postby the fallen303 » Tue Apr 01, 2008 8:40 pm
car flew through, so didn't need a recheck, so not sure wether it was a recheck within the 2 months or not that cost extra
true house of JZ
the fallen303
cert
Postby docTRD » Wed Apr 02, 2008 4:22 pm
i just had my cressida certed 2 weeks back and i needed few things for the cert so did them but the guy from nostaliga motors said they usually charge an extra $100 for recheck but waived it on myn since it was just small things like securing the high stop light and needed a fan shroud. so i guess it depends how anal the certifier is !
Daily : st191 corona liftback mmm room
Project : Jzx90 mark2 Tourer V
--- wtd: corolla GT ae92 sedan ---
"Mum i knw its another wreck, i only got it so i can put the seats in the lounge" YEAH RIGHT
docTRD
Mo Joe
Postby postfach » Wed Apr 02, 2008 5:22 pm
I think certifiers can charge whatever they want anyway, so perhaps different guys will have different conditions/costs associated with a retest?
postfach
Postby Simon K » Wed Apr 02, 2008 9:06 pm
Here's my dilemma.
I might look at an engine conversion in the near future...going from a 175hp SR16VE to an SR20VE with a handful more kilowatts but a bucket load more torque. At what point is a cert required, considering SR20's are actually fitted to Pulsars from factory?(SSS for example)
Simon K
TS Wannabe
Postby Alex B » Wed Apr 02, 2008 9:08 pm
Still need a cert. Just pain the rocker cover blue, who would know. :wink:
Postby Lloyd » Wed Apr 02, 2008 9:13 pm
ANY increase in displacement requires a cert
Much like how anything factory fitted with a 3K that now has a 4K should be certified. Though warrant inspectors usually go by that fact that the difference between a 12hp engine and a 12hp engine that revs out 2 grand further is nothing.
Postby Simon K » Wed Apr 02, 2008 9:29 pm
pyro_sniper2002 wrote:Still need a cert. Just pain the rocker cover blue, who would know. :wink:
They're both blue :wink:
Yeah I figured it's safest to get one, might make the insurance co happy too.
Simon K
TS Wannabe
Postby l1ttle_d3vil » Thu Apr 03, 2008 8:20 am
HRT wrote:ANY increase in displacement requires a cert
i thought it was a 25% increase in power and you needed a cert (aslong as it was a bolt-in etc). have they changed it now?
Postby Lloyd » Thu Apr 03, 2008 12:38 pm
Its always been like this, and is explained in the VIRM.
Cert needed for:
- increase in displacement
- increase in engine weight
- increase in engine power
- different fuel
- modified mounting points
- different engine configuration
- etc
http://www.landtransport.govt.nz/certif ... -13-v3.pdf
Table 13.1.1
The 20% increase thing is separate from that, it is for when you modify a standard factory fitted engine.
