crazy 4age problem
crazy 4age problem
Postby Mike- » Wed Apr 09, 2008 5:16 pm
the engine is a redtop tvis standard except for pod filter,
the problem reminds me of the audi guy who put sand in his intake, the engine bucks alot and doesnt idle,
i took the pod filter off and opened the butterfly valve and quite a bit of smoke came out the intake!
then i took the plugs out and turned it over by hand, it seemed fine
then took the cam cover off and the match marks on the cam pulleys are in the right place.
before this happened it was running good.
all i can think of is that something is blocking the exhaust but i cant see any potatoes or balloons.
Mike-
Postby tsoob » Wed Apr 09, 2008 6:26 pm
is there a split in one of the many vac lines?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Mike- » Wed Apr 09, 2008 7:10 pm
no splits in the vac lines,
also its rwd in a ke70 if that makes any difference.
Mike-
Postby bluemaumau » Wed Apr 09, 2008 8:44 pm
does the oil brether go into the inlet? could be that? :?
Postby Mike- » Thu Apr 10, 2008 5:43 pm
nope the oil breather goes to nowhere,
the engine sounded like it was running on two cylinders and wouldnt idle at all, was hard to start (turned over ok but wouldnt fire). when i gave it gas it sounded really sick and violent.
Smoke came out the inlet when i took the pod off!
has anyone had this problem before??
Mike-
Postby l1ttle_d3vil » Thu Apr 10, 2008 7:07 pm
valve timing might be right, but have you checked the spark timing? might be out a tooth or something?
Postby rollaholic » Thu Apr 10, 2008 7:42 pm
did you check the crank timing mark as well - was the cambelt replaced or removed before the engine was put into the car? has it run previously or is this the first time you've tried to get it going?
lots of smoke in inlet manifold does not sound good.
Postby Mike- » Thu Apr 10, 2008 9:23 pm
nah ran sweet the night before, havnt checked the spark timing, dont have a light.
Mike-
Postby l1ttle_d3vil » Thu Apr 10, 2008 9:46 pm
dont worry about the light, just make sure it isnt a tooth out - when you're certain its correct, just move it back and forth and see where it runs best. no the most ideal way, but will tell you if its the timing or not.
Postby pc » Fri Apr 11, 2008 1:52 am
do a compression test.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Users browsing this forum: Google [Bot] and 19 guests
