What should tyre pressures be on my Supra for:
215/45/17 front and 235/45/17 rears
xsspeed wrote:that high? i used to go for 35 on my falcon when i had 18s.
do you suggest this psi to avoid wear on outer edges?
AE82 FXGT wrote:Wear on outer edges, is probably more a wheel alignment problem, too much/little camber or toe.
rollaholic wrote:then again most of the falcons and commy taxis we see at work seem to wear the outer edges on the front and the inners on the back!
rollaholic wrote:AE82 FXGT wrote:Wear on outer edges, is probably more a wheel alignment problem, too much/little camber or toe.
i would agree if one shoulder was wearing, but if both are wearing faster than middle of tyre its more likely to be underinflation
