ke35-hilux diff!!
ke35-hilux diff!!
Postby ke_25 » Wed May 07, 2008 5:40 pm
just been sorting out my hilux doff to go into me ke35 and hadent really though about it till today, but teh u bolts for a hilux are 75mm, and the ones for a u series ke30 diff are ##? smaller! what have people done to teh bottim plate under teh leaf to accomodate for thid to make work?!
am also running the hilux leaf mounts, did anyone keep these or change over? just dont want to run into assembly problems
cheers shaun
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby terola » Thu May 08, 2008 3:55 pm
make another one out of 6mm or i use 10mm plate nice and strong.just get the distances between the u bolts from the old plate and then work out centres of ubolts and drill clearance holes for the new u bolts and ull be away.as for leaf mounts depends what size the hole in them is other than that cant think of a reason why not.as long as they are the right distance apart hah
terola
Postby ke_25 » Thu May 08, 2008 7:22 pm
what about the shock mount? as this is on this bottom plate also? or are you talking about the steel cover that goes over the leaf and joins to bottom plate?
ke_25
Postby l1ttle_d3vil » Thu May 08, 2008 8:28 pm
ke_25 wrote:what about the shock mount? as this is on this bottom plate also? or are you talking about the steel cover that goes over the leaf and joins to bottom plate?
the ones terola done were for a ke25 - their shocks bolt to the diff i think. just weld some threaded rod or something onto the end of the plate.
as for the top one which goes over the leafs you should be able to get away with slotting those holes a bit. the ubolts i had for my hilux diff were the same width as my ke30 diff... :?
Postby ke_25 » Thu May 08, 2008 8:37 pm
so the bottom plate you used for your 30 diff worked or the larger u bolts also? i guess i could bow them in, 30 u bots def dont fit over the lux diff
ke_25
Postby terola » Fri May 09, 2008 1:12 pm
ohyea my bad forgot how different the setups are.ud need to slot bottom plate aswell quite a bit i would think id rather make another bottom plate.photos mite be easier i only really know ke2* shit
terola
