Clutch Driven plate orientation
Postby xsspeed » Tue May 20, 2008 11:52 am
Hey guys maybe a dumb qustion but ive just put my clutch on and am unsure if its the right way around,
looking at the clutch assembly side on as shown there is a larger protrusion from the clutch on on side than the other, currently i have this side facing the clutch cover (right hand side below), and the smaller protrusion side facing the flywheel (left hand side below)
is this correct, i was trying to go by what was done on the old clutch but that was a pbr and this is toyota genuine, so slightly different shapes, added to the fact that i dropped the old driven plate when i pulled the cover off so not 100% sure which way round it was.
unfortunately the driven plate doesnt say flywheel side or whatever.
hopefully i dont need to unbolt and take pics to explain better, unless of course its on the wrong way.
also anyone in central auckland got a clutch alignment tool? i've so far just lined it up using a screwdriver.
Postby sergei » Tue May 20, 2008 12:04 pm
skinny part to the flywheel, fat part to the pressure plate, you will not be able to bolt on pressure plate properly if put wrongly.
Postby xsspeed » Tue May 20, 2008 12:07 pm
sweet thats what i figured just needed confirmation
Postby rollaholic » Wed May 21, 2008 6:38 pm
easiest way to align a clutch without the tool is by feeling the lip on the pressure plate to the clutch plate. theres usually three spots where you can do this, spaced evenly around the circumference. if the lip is the same on all three, your clutch is aligned!
Postby nz_climber » Wed May 21, 2008 10:37 pm
just make a clutch alignment tool, all you need is a 15cm piece of broom stick and 10 min's on a lathe..
nz_climber
Postby postfach » Wed May 21, 2008 10:52 pm
or an extension from a half inch socket set and some electrical tape!
postfach
Postby AE82 FXGT » Wed May 21, 2008 11:01 pm
the electrical tape one works good too. :lol:
AE82 FXGT
Postby Zak » Wed May 21, 2008 11:05 pm
rollaholic wrote:easiest way to align a clutch without the tool is by feeling the lip on the pressure plate to the clutch plate. theres usually three spots where you can do this, spaced evenly around the circumference. if the lip is the same on all three, your clutch is aligned!
This man speaks the truth, no other way works better, unless you doing a multi plate clutch.
Zak
Postby Mr Revhead » Wed May 21, 2008 11:44 pm
cheapest method that never fails me is the mk1 eyeball!!
Postby rollaholic » Thu May 22, 2008 12:49 pm
yeah, i actually prefer this method to the clutch alignment tool, particularly on FWD vehicles with no spigot bearing.
Postby xsspeed » Thu May 22, 2008 12:55 pm
Mr Revhead wrote:cheapest method that never fails me is the mk1 eyeball!!
best tool i have in the shed atm :lol:
thanks rollaholic and zak, that makes sense i will do that to check the calibration of my eyeball tool
