So im finally doing putting a 1j into my na mk4 supra
Postby Coke » Tue May 20, 2008 11:28 pm
Im bored and want boost so im putting a low km 1jzgte into my 93 aero supra.
Have spoken to a guy thats done it so I realise there will be a bit of wiring involved.
Anyone here done this?
Swap will be happening in uni holidays (1 month) in Hamilton.
Know any good auto sparkys in Hamilton?
Will have a mint 2jzge for sale as well.
Coke
Postby Bling » Wed May 21, 2008 12:05 am
Postby Coke » Thu May 22, 2008 12:50 am
Thanks
Coke
Postby BlakeNZ » Thu May 22, 2008 2:51 pm
what trans are you running?
BlakeNZ
Postby Coke » Thu May 22, 2008 7:39 pm
Not sure yet, seeing what I can get sent over-would like to end up with a r154. Could go with a jza80 w58. what you rekon?
Coke
Postby BlakeNZ » Thu May 22, 2008 8:20 pm
go for the w58 if you are not going to run more than 250rwkw. nicer to drive than the r154. if you haven't bought the engine already, you should seriously consider going to www.otomoto.com.au and clicking on turbos, then "NEW KIT". the jza80 upgrade kit is awesome, . 250rwkw at 12psi, strong off boost too.(twice the power you have now) you could keep costs down by doing the intercooler kit yourself(trade me $500) and buying turbo injectors (430cc) quite commonly available(replace your factory 315cc ones. you wont need to upgrade fuel pump- its perfectly capable of those power levels. the real key in tying it all together would be that adaptronic plug in ECU. put the electrician costs that you would have spent, towards that maybe. just something to consider. you wont need to pull the motor,or feel sad when someone picks up your mint 2JZGE for under $500!
BlakeNZ
Postby Coke » Thu May 22, 2008 9:40 pm
Cheers for that link! I have thought about what your suggesting but been told I would need to upgrade my headgasket if I want to turbo the na. Will give it more thought tho. And yea think you right about the gearbox, I cant imagine massive power levels for what I want to do so w58 it is.
Coke
1jz
Postby docTRD » Thu May 22, 2008 10:06 pm
score my 1jzgte and il help put it in and hook it up etc should be prety straightforward
Daily : st191 corona liftback mmm room
Project : Jzx90 mark2 Tourer V
--- wtd: corolla GT ae92 sedan ---
"Mum i knw its another wreck, i only got it so i can put the seats in the lounge" YEAH RIGHT
docTRD
Mo Joe
Postby BlakeNZ » Thu May 22, 2008 10:52 pm
yeah you wont need to decompress the motor as long as you run sensible boost(obviously 12psi is fine) and (importantly) you have a safe tune.
BlakeNZ
Postby spencer » Fri May 23, 2008 5:27 pm
hey mate I can wire it up pm sent
ms63 crown
spencer
Postby mjrstar » Fri May 23, 2008 6:19 pm
I run 20 psi in my internally stock engine naturally aspirated engine. As people have said above it all comes down to a good tune.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
meh
Postby ezy10s » Fri May 23, 2008 6:38 pm
subaru leagcy map sensor- 4agze injectors with a t3/t4 turbo on 12psi worked a treat for my NA 1jzge engine
Member #244
ezy10s
