Electrical Problem - Urgent
Postby solitaire » Sat May 24, 2008 1:39 pm
Hi All,
Pretty freaked out right now...
I just finished putting an amp and some components in our AE111 Wagon. It was all plugged in and running well, a 50amp fuse built into the amp and a 40 amp fuse by the battery. The unit is grounded to the seat mounting point.
I had just finished putting the car back together when i remembered the wife moaning that the cigarette lighter doesnt work.
Ill note that i had the car stereo running all morning fine, the key set to AC but has been set to on a few times when i was testing the electric windows.
I messed about with the cigarette lighter connections a bit, re-seated them and plugged in an ipod to it and the ipod started charging... So i put the dash back together. Once all was finished i tried to fire up the ipod and found it was no longer receiving power. I sprayed a little bit of crc into the cigarette lighter in the hope of cleaning the connections (now regretting this) i then put a fluke meter onto the connections and found the voltage to be 7 volts and slowly decreasing.
I tried to start the car and the starter motor went "click" and everything in the car died, no dash warning lights, no stereo, no clock.
I unplugged the fuse from the amp in case i had done something and checked the battery, just over 12 volts. I then set the key to "on" and check again, still the same reading.
I have checked the fuses but there are some big black ones that i cant see through so im not sure how to check them.
Anyone have any ideas? The wife gets home at 5pm and she is likely to be less than impressed 8O
AE92, KZJ120, KDJ120
solitaire
Postby slighty_sykotic » Sat May 24, 2008 1:43 pm
Sure u just havn't run the battery flat?
Jump start it?
slighty_sykotic
Postby solitaire » Sat May 24, 2008 1:45 pm
slighty_sykotic wrote:Sure u just havn't run the battery flat?
Jump start it?
I had thought that because it was set to on with not even a clock and the battery was at 12v that would mean that the battery was fine... but ill dash down and do that now...
solitaire
Postby method » Sat May 24, 2008 1:45 pm
Sounds like a flatty to me too
PICS UPDATED DAILY
method
Postby solitaire » Sat May 24, 2008 1:55 pm
Put another battery on and everything came back up BUT
As soon as i tried to start it the same thing happened... everything went dead... if i disconnected the same battery and then reconnected it a moment later the power would come back but dissapear again the instant i tried to start it...
help! 8O
solitaire
Postby Alex B » Sat May 24, 2008 1:58 pm
Are you sure the other battery is fully charged. It just sounds like flat. It doesnt matter your battery has 12V with no load on it. Turn the head lights on for a second and measure it with lights on.
Postby RedMist » Sat May 24, 2008 1:59 pm
Poor Main Earth. Trace where the battery ground terminates at the chassis. Remove it, clean the contact and where the contact mates to the chassis.
Or poor main positive connection to the starter. Same solution as above.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby rollaholic » Sat May 24, 2008 2:39 pm
dont go near positive on starter with batt connected unless you want a crash course in arc welding :D
Postby method » Sat May 24, 2008 2:57 pm
Yeah, make sure the battery you use is charged.
It could have 12V at 0.1 amps but only 3 or 4 volts when a 50A starter is trying to crank over
PICS UPDATED DAILY
method
Postby solitaire » Sat May 24, 2008 2:58 pm
method wrote:Yeah, make sure the battery you use is charged.
Yeah im thinking your right... have to wait for the wife to get home... fingers crossed...
Thanks for the fast responses guys... very much apreciated :D
solitaire
Postby tsoob » Sat May 24, 2008 6:41 pm
GIVE UP SMOKING !!
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby solitaire » Sat May 24, 2008 6:51 pm
tsoob wrote:GIVE UP SMOKING !!
:lol: I dont... im just a spaz... i have tried to quit being a spaz for years but its hard...
solitaire
Postby AE82 FXGT » Sun May 25, 2008 2:29 pm
rollaholic wrote:dont go near positive on starter with batt connected unless you want a crash course in arc welding :D
How bout disconnecting the batt first? :lol:
Car have an alarm at all?
AE82 FXGT
Postby solitaire » Sun May 25, 2008 5:05 pm
Yeah a 5 star mongoose thingie
It was the battery - 16 hour charge later (8am this morning) and she roared into life which was lucky because we really needed the corolla today (been out and about with a 2 axle braked trailer all day... what a trooper the wagon is)
Thanks again everyone - sorry i did not update sooner but only found out this morning and had to dash out when it started.
solitaire
Postby rollaholic » Sun May 25, 2008 6:14 pm
yeah thats what i was getting at :P
