fitting Factory Sideskirts: St205 celica
Postby Prymal » Sun Jun 01, 2008 5:07 pm
heys - a real uicky before i go poing about in my sills - I have a set of Factory sideskirts to go onto my Gt4 , they are ready to fit
I need to know if you need specific clips to affix them to the sills , or whther you use the ones that plug up the holes in the sills already there ..
Ive looked underneath , found the plugs ( plastic not rubber ) where the skirt mounting points will align , but i dont want to destroy them if im to use them ..
Any help would be good please !
Prymal
Postby muppet » Mon Jun 02, 2008 3:01 pm
Just doing the same thing myself but to a ST202--fitting side skirts.
Painted them up and place them up againist the car and found that the drain holes are just that! not mounting holes
I'll have to drill holes in the sill for the push in clips, so I'm leaving that job to a panelbeater
muppet
Postby Prymal » Mon Jun 02, 2008 6:48 pm
are they genuine factory ones - or not ? im curious now ..
Prymal
Postby muppet » Mon Jun 02, 2008 8:14 pm
Mine are second hand from a GT4, so a GT4 might have the mounting holes there already, I don't think that all GT4's come with body kit fitted.
muppet
Postby Prymal » Wed Jun 04, 2008 7:14 pm
officially mines not to have it - its an experiment n looks. I like the factory kit - ahve seen the smae on a friends of mines group A in AUS and it looked vety suiting to a street car .. if i find it doesnt suit - it will come off and it ill go a lot more hardcore rally in appearance and additions
Prymal
Postby muppet » Wed Jun 04, 2008 10:21 pm
Mines taking the rally look with the Gt4 rear wing and rally flaps all round.
muppet
Postby Prymal » Fri Jun 06, 2008 7:00 pm
heh i have those - ell the wing is factory , the flaps i have here as well .. will cosnidr it if i decide to ditch the skirts , will try again to fit them this weekend then im off to hamilton to see if i can find a suitable front lip
have to have the car semi ready this month as im hoping to take/display it at the WRC round at the special stage in hamiltom
Prymal
Postby Prymal » Sun Jun 08, 2008 2:51 pm
well i hit a snag - 3m adhesive tape left on the old skirts , bloody near impossible to get off ..
Ive tried a number of things to remove the goo left behnd so new adhesive can be layed down , but havig a hell of a time getting the old stuff off ? Any points or tips for this ?
remeber ABS plastic - so harsh chemicals might fail , and heat is a no no - as it will melt it
Prymal
Postby muppet » Mon Jun 09, 2008 9:38 pm
Yeah had the same problem with my ones too. Used a heat gun to help remove the film and then srapped away most the glue left with a bluntish knife and then sanded the rest off.
Pretty painful but was the only way that I could find to get it off.
muppet
Postby barryogen » Tue Jun 10, 2008 9:19 am
I've used the edge of a CD to remove this sort of stuff in the past. you have to use it at a fairly flat angle though as they are almost sharp enough to scratch paint.
barryogen
2ZZ Guru in training
Postby Prymal » Mon Jun 16, 2008 11:43 am
i got the goo off - hours of gentle razorblade to remove the excess foam then 3m adhesive remover did the trick - should have them on , still waitiing on the poly sealant and a dry day to remove the clips in the sills !
Prymal
Postby Prymal » Mon Jun 30, 2008 3:12 pm
got the clips out - found i need to source some grommet style clips from Mr T
a handy curren with the same skirts nearby provided the answer ..
bad news is i got ran into last weekend - so finishing the kit has been delated till the accident damage is fixed !
Fugg!
Prymal
