not toyota but ...
not toyota but ...
Postby escortman » Mon Jun 02, 2008 1:38 pm
ok so iv got to get my escort out of the garage to pull my fx apart ... again
wen i last had to start it i had to replace starter solinoid, i also replaced condenser, and it ran i have started it a few times over the last couple years and it started 1st time but now for some reason it wont, spark, iv got 12v to the coil, and i tested the coil on my sisters car and it works fine, is there something else i i could test ?
4x4 toyota blizzard offroader
escortman
Postby rollaholic » Mon Jun 02, 2008 1:58 pm
how do you know its not sparking? earthing a sparkplug out somewhere?
if the coil is ok, it'll probably be something in the distributor. but having 12v feed at coil doesnt mean its working properly ;)
Postby escortman » Mon Jun 02, 2008 3:03 pm
ok sorted it haha ran a new wire form starter solenoid to coil thinking wire maybe goosed after cleaing plugs and blowing it out a bit, got it 2 run but had to make it run with the starter motor :lol: so i tried the old wire again and yeh now it runs so not sure y it wouldnt haha
escortman
