HELP! car jolts everytime i shift gear... Faulty TPS?
Postby kim0663 » Sun Jun 15, 2008 6:25 pm
Ive got a 91' Trueno, 20v silvertop. Done around 170xxxkms now,
When you press the gas, it hesitates at a certain point (its around like as soon as i start pressing the gas) and then goes okay after that. So everytime i change gear, the car sort of jolts and then goes.
Didn't mind too much about it b4 but im guessing this can't be good for fuel :twisted: .
Im thinking about cleaning the Throttle bodies to fix it? If anyone else knows the cause of this, please let me know so i don't waste my time on trying to clean 4x throttles :cry:
Mr2 GT-S
330ci M
kim0663
Postby kim0663 » Mon Jun 16, 2008 3:26 pm
anyone 8O ?
Mr2 GT-S
330ci M
kim0663
Postby DexGT » Mon Jun 16, 2008 7:54 pm
your rear engine mount could be stuffed , it would cause results similer to what you have . try moving the motor by hand at the top ,this should give you an idea of whether to investigate further
DexGT
Postby TRD_ZERO » Mon Jun 16, 2008 9:02 pm
Could it not be the same problem with most blacktops ....that little flatspot during acceleration.
TRD_ZERO
Postby FULLOC » Mon Jun 16, 2008 9:14 pm
my girls new silvertop levin does the same. was thinkin grubby throttle body too but if anyone has a good suggestion il give it a go.
FULLOC
Postby GDII » Mon Jun 16, 2008 9:38 pm
My car did that. But its not a silver top. Just a 2E carb. I replaced the leads and went fine after that.
GDII
Postby 79rolla » Mon Jun 16, 2008 9:44 pm
fule filter? had problens worse then that on the 4k... just a shot in the dark...
past: AE82 FXGT
79rolla
Postby kim0663 » Mon Jun 16, 2008 11:08 pm
hmm leads eh...?
Well im gonna rip out the throttles tomorrow and give em a good clean first because cleaning them costs alot less than ht leads :lol:
Might even take out the fuel filter and give em a good blast with the air gun too.
will post how things go.
Mr2 GT-S
330ci M
kim0663
Postby ae86_gtz » Tue Jun 17, 2008 12:00 am
do a diagnostic test and see if you get anything. knock sensor does that kind of.
Toyota Trueno AE85 Turbo
ae86_gtz
Postby lucasthefallen » Tue Jun 17, 2008 8:40 am
you cant clean the fuel filter you wolly
Need Service or Repair work done? send me a PM
lucasthefallen
Postby GDII » Tue Jun 17, 2008 9:37 am
kim0663 wrote:hmm leads eh...?
I got them really cheap :lol: It was the last thing on my list to try and get it running properly.
But obviously mine isn't EFI so it might not be that.
GDII
Postby tsoob » Tue Jun 17, 2008 9:58 am
lots of different ideas again fullas, its gonna be process of elimination,
my car once had a problem like this it was the factory intake pipe had a large split in it and needed replacing, we used duct tape and it was ok for a while. also can be any one of the other things mentioned here or even something else.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby RS13 » Tue Jun 17, 2008 10:38 pm
I realise you've got quads, but my 16V did that, almost as soon as your foot touched the gas pedal, it would give a little "kick", then drive as normal, turned out I'd pulled a vacuum line off the throttle body accidentally. I too thought it was a buggered engine mount, even rang around getting quotes in the hundreds of dollars for a new set! lol.
RS13
