RWD Prop Shaft - Slip - which models have it?
Postby MrOizo » Thu Jun 19, 2008 11:55 pm
Does anyone know which RWD toyotas came with a slip mid length on the prop/tail shaft?
Looking for something toyota that has this slip system mid way down the shaft.
Preferably if i can find ones that have bolt holes 65-67mm spaced that would be awesome :)
like the pic below (the bottom one):
MrOizo
Toyspeed Legend
Postby thegreatestben » Fri Jun 20, 2008 12:10 am
that big rubber donut is suggesting lucida/estima to me?
thegreatestben
Postby MrOizo » Fri Jun 20, 2008 12:13 am
i'm not necessarily after one like the one in the pic but just something that has these slips down the shaft rather at the box itself.
I am going to PAP tomorrow so i will have a look at the estima's if they are even there.
cheers.
MrOizo
Toyspeed Legend
Postby thegreatestben » Fri Jun 20, 2008 12:17 am
if the rubber bit is the part that connects to the gearbox a jellybean/estima would be your best shot.
thegreatestben
Postby matt dunn » Fri Jun 20, 2008 12:50 am
Not relly sure what your planning on doing with it,
but most 4WD hilux and 4WD van stuff had that slip type joint at the front?
Postby nz_climber » Fri Jun 20, 2008 8:49 am
not sure if it would help, but the top shaft in the picture is very similar to my altezza drive shaft I have sitting here waiting to be shortened.
nz_climber
Postby fangsport » Fri Jun 20, 2008 6:31 pm
matt dunn wrote:but most 4WD hilux and 4WD van stuff had that slip type joint at the front?
would depend on the bolt spacing as to which on to use. i know the 4wd liteace vans use a very similar spigot and bolt fitment as the T series rear end pinion flange.
best option would be solid front Hilux or Landcruiser
fangsport
