flywheel spacer
flywheel spacer
Postby bluemaumau » Sun Jun 29, 2008 10:38 pm
ive asked a few people and im still a little lost.
ive got a 4age 20v(silvertop auto) crank and block
and a e58(ae101 gtz lsd) flywheel.
then i found these spacers.
im 99.9% sure one is from my old 4agze setup and the other is form the auto 20v.
so im asking for confirmation on which one to use and where exactly it goes
e.g
between crank and flywheel or between flywheel and bolts.
note
one is around 3-4mm thick (left)
one is dished and around 1-2mm thick (right)
pics:
TIA
Postby escortman » Sun Jun 29, 2008 10:55 pm
hahaha googd timign just got ur pm when i opend the thread
i didnt have one on the motor that was in my car, but the smallport motor i just pulled apart had a 2mm one between crank and flywheel
hope that helps
4x4 toyota blizzard offroader
escortman
Postby l1ttle_d3vil » Sun Jun 29, 2008 11:02 pm
hah same with me, never saw one on my bluetop setup (hope they weren't required).
but there was one on my manual 4agze engine, pretty sure its the 3-4mm one in the left of your pic. and fairly sure its between the flywheel and crank/block.
Postby bluemaumau » Sun Jun 29, 2008 11:28 pm
hope that helps
which way was it curving towards?flywheel or crank
Postby escortman » Sun Jun 29, 2008 11:35 pm
i think both sides were round edges, i would say it would go like |(- the | been flywheel and - been crank but ill have a look 2moro
escortman
Postby matt dunn » Mon Jun 30, 2008 1:05 am
escortman wrote:i think both sides were round edges, i would say it would go like |(- the | been flywheel and - been crank but ill have a look 2moro
that too is how I suggested, but I was not 100% sure.
Postby 20v_rollaboy » Mon Jun 30, 2008 2:04 am
Ive never seen one on any of my manual engines, but I have found them on the auto ones Ive taken apart.
When I did put my e58 on the liftback, I didn't use any spacers
20v_rollaboy
Postby Jason T » Mon Jun 30, 2008 9:19 am
Spacers are used on flex plate of auto engine.
Thick spacer goes to crank shaft thin is bolt side with curved side away from flex plate face
Manuel Toyota engines never have spacers between crank shaft and flywheels from factory.
Only auto engines.
Fixing Toyota's since '87
Jason T
Postby Crampy » Mon Jun 30, 2008 9:31 am
That's what I thought. I've never seen a spacer on any of my 4AGEs or 4AGZEs. Leave them out I say!
Crampy
Postby bluemaumau » Mon Jun 30, 2008 9:54 am
cheers for everyones help
