just putting things back together and need to know where a few things go to
car is a ae101 map sensored 4agze
1. where is the 'turbo pressure sensor' bolted to and where does the vacuum line go.
2. what connects to the pipe on the lower pulley side of the supercharger.
3. where does the small vacuum hose with a small round filter looking thing attatched to it go?
4. where does the larger pipe on the inlet pipe go to.
5. with the hoses on the side and bottom of the throttle body, can the hoses go in either the left or right pipe?
