vacuum hoses in ae101 4agze
Postby Mike- » Mon Jul 07, 2008 9:21 pm
just putting things back together and need to know where a few things go to
car is a ae101 map sensored 4agze
1. where is the 'turbo pressure sensor' bolted to and where does the vacuum line go.
2. what connects to the pipe on the lower pulley side of the supercharger.
3. where does the small vacuum hose with a small round filter looking thing attatched to it go?
4. where does the larger pipe on the inlet pipe go to.
5. with the hoses on the side and bottom of the throttle body, can the hoses go in either the left or right pipe?
Mike-
Postby AE82 FXGT » Mon Jul 07, 2008 9:33 pm
Hard to say without pics,
1) The map sensor line comes from the intake manifold on the coil side of things, it's te only line coming from there (I took mine off this weekend just been, I used a twink pen and put marks on all the vac lines),
4)By larger pipe you don't mean the breather that goes into the rocker cover do you?
AE82 FXGT
Postby Mike- » Mon Jul 07, 2008 9:37 pm
ok found the map sensor one, any help with where to mount the bracket its on?
and no 4 is the breather :P
Mike-
Postby AE82 FXGT » Mon Jul 07, 2008 10:14 pm
map sensor itself bolts to the a bracket that comes of the rear rocker cover beside the coil packs IIRC
AE82 FXGT
Postby Bazda » Mon Jul 07, 2008 10:19 pm
http://opc.mr2oc.com/
many 4agze and 4age vacuum diagrams etc
Postby AE82 FXGT » Mon Jul 07, 2008 10:21 pm
Yay, Bazda to the rescue, I was just looking for that, and was about to go have a look in the garage at mine.
AE82 FXGT
Postby themaleman » Mon Jul 07, 2008 10:30 pm
thell be a big pipe for the brake booster, will be a a couple medium? sized hosescoming off the inletand going down to the steering rack
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
