Caldina Trans/Centre Diff Oil
Postby Stu- » Sun Aug 10, 2008 5:53 pm
Does the centre diff/transfer have its own oil supply or is it fed from the trans?
Project Thread
Stu-
Postby cedwards » Fri Feb 27, 2009 4:21 pm
Seems to be a seperate unit. anyone know where the filler/level cap is???
castrol multitrax all good?
cedwards
Postby Stu- » Sat Feb 28, 2009 12:35 pm
Yes defintily a seperate unit, its quite tricky to get to as well. Its got a filler hole and a drain - similar setup to gearboxes, you fill till fluid level reaches the filler hole
Project Thread
Stu-
Postby cedwards » Sat Feb 28, 2009 6:20 pm
cool, but where? is the filler hole had a look yesterday but cant seem to see it?
Multitrax all good to fill it with?
cedwards
Postby bbq1988 » Sat Feb 28, 2009 6:53 pm
cedwards wrote:cool, but where? is the filler hole had a look yesterday but cant seem to see it?
I think it gets filled via the gearbox, mite check later
bbq1988
Postby Stu- » Sat Feb 28, 2009 7:03 pm
Its up underneath the car - look where the drive shaft enters the transfer case and its right above it
Project Thread
Stu-
Postby cedwards » Sat Feb 28, 2009 7:33 pm
sweet wiil do had a look there but without taking wheel off, do you go in through wheel arch or from underneath?
What oil did you use? same as gearbox? or does the LSD req something special Toyota said multitrax but seemed a bit vague :?
cedwards
