d1 mule wrote:ANY IDEAS?? a mechanic mate thought fuel pump relay??
d1 mule wrote:i took 1 out and with the lead on earthed it on the chassis .
d1 mule wrote:problem seems to be solved, after replacing the dizzy its not faulted once. however its impossible to time it properly, @ 10-15 degrees base timing it runs like a bag of sh*t, only runs good at approx 30 advance. its really weird we ended up just seting it by feel which is approx 30-35 advance at idle.
it also has a high idle approx 1400rpm?????????
its only throwing code 11 which is someting to do with the air con switched at the TPS so i doubt its that.
so not perfect but its good to be able to drive it again
d1 mule wrote:ok sweet, new tps it is
cheers man
