supra rear wheel bearing
Postby avinesh » Mon Aug 18, 2008 11:17 pm
drivers side rear wheel bearing on a jza80 supra is this hard to change???? Any nasty suprises i gotta look out for cheers....
220.1 rwkw
jzz30 bpu soarer auto = 13.3 @ 171 km/h
jza80 supra = 11.7
jza80 apu supra manual = 400rwkw
avinesh
Postby avinesh » Tue Aug 19, 2008 2:02 pm
symtoms i get is sometimes there is a little clank noise when i use the brakes or when i turn around a corner........rear wheel also has up an down play......cant really hear any noise like humming or grinding, does this sound like a wheel bearing issue?????
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby MrOizo » Tue Aug 19, 2008 4:19 pm
could see if the nut on the shaft is done up nice and tight?
MrOizo
Toyspeed Legend
Postby avinesh » Tue Aug 19, 2008 4:29 pm
MrOizo wrote:could see if the nut on the shaft is done up nice and tight?
yup it is we made sure by using a 1.5meter iron rod as a lever on the wretchet 8O
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby avinesh » Wed Aug 20, 2008 1:05 pm
if wheel only has play in one direction what does it mean coz i heard wheel bearing will cause play in all directions.... the wheel does seem to have any play from side to side it only has play when you grab the bottom side an the top :? what could this be????
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby mr_monkey » Wed Aug 20, 2008 6:22 pm
For gods sake.
Take the wheel off and have a look!
Previous rides: 1992 Toyota Trueno, 1992 Nissan GTI-R, 1985 Toyota AW11, 1990 Toyota SW20 Turbo, 1994 Toyota Supra Twin turbo, 1991 Toyota Soarer Turbo, 1991 nissan Safari
Cogent wrote: there is a fraudulent cogent-post in your sig and i insist that you cease displaying it immediately or else i'll track you down and perform acts of homosexuality on your face
mr_monkey
Postby avinesh » Wed Aug 20, 2008 10:42 pm
mr_monkey wrote:For gods sake.
for god sakes i did man :evil:
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby Bling » Wed Aug 20, 2008 11:41 pm
well in that case put it back on and drive it till it falls off. Then replace bearing 8)
I would have thought if the bearing was shot you'd have play in all directions, and would be able to feel vibrations in the wheel if you spun it by hand. (i've only dealt with a couple of bung wheel bearings tho)
Postby postfach » Thu Aug 21, 2008 2:07 am
Sounds like a bush to me, I had a worn one on my z20 which had play like you describe, don't know about noises tho cos there are so many other rattles etc in that car.
postfach
Postby rollaholic » Thu Aug 21, 2008 9:10 pm
if wheel bearing is worn you should be able to feel it through the spring - put your hand on spring and spin wheel, can compare to another wheel to feel the difference if needed.
Postby avinesh » Fri Aug 22, 2008 2:06 am
it was the wheel bearing.....changed it out all good now, things to note are it wont always make noises an wont always have play in all directions, it had a deep groove in the old bearing, wheel doesnt have play anymore............. :)
220.1 rwkw
jza80 supra = 11.7
avinesh
