20v problems -ae92 fxgt
Postby deaf_rattle » Wed Aug 27, 2008 7:13 pm
Got a water leak coming from the back of the engine. too dark to see where its coming from now, but is there a hose or pipe that i should be looking for?(or pipe that commonly fails?)
speedo stopped working as well, likely to be just the speedo cable? or something else i need to check.
ecu gives me code 42
VEHICLE SPEED SENSOR SIGNAL CIRCUIT--NO SPD. SIGNAL FOR SEVERLA SECONDS
WHILE VEHICLE IS OPERATED UNDER HEAVY LOAD (TPS/MAP/AIR FLOW INPUTS)
--SPEED SENSOR/CIRCUIT
--ECU
Postby ChaosAD » Wed Aug 27, 2008 8:57 pm
Yup, theres a pipe running along the back of the block, it has a short rubber joiner joining it to the waterpump
ChaosAD
Postby deaf_rattle » Wed Aug 27, 2008 8:59 pm
cheers mate
just found it in this pic
most likely to be that hose? or water pump spitting the dummy?
Postby rollaholic » Wed Aug 27, 2008 9:19 pm
could be either, think its going to have to wait till daytime :D
unless you have a torch and really want to find out tonight :P
Postby ChaosAD » Wed Aug 27, 2008 10:43 pm
actually I think it comes out of the waterpump and does a loop and goes into the head or block as in the pic, but you can see the rubber joiner.
It was the 16v that had the pipes running along the back of the block.
Could be either, usually when the water pump packs it in water leaks out of a drain hole on the pump itself
ChaosAD
Postby deaf_rattle » Sat Aug 30, 2008 3:59 pm
well ive had another look, but cant see where its leaking, its only while engine is running but other than that i dont know
the main hose from the water pump looks alright and the leak seems to be coming from the bottom of the waterpump
has anyone replaced the waterpump in place? or will the engine need to come out?
I presume the front covers etc need to be removed to take the pump off?
Will take the alternator off so i can have a better look at the pump.
Postby deaf_rattle » Sat Aug 30, 2008 6:24 pm
well, just removed the alternator and bracket and i can clearly see water coming out of the bung from the water pump.
Is this a fail safe for the pump?
has anyone replaced the pump whilst its in place? or will i need to pull engine?
Postby Cakky » Sat Aug 30, 2008 6:48 pm
I know it can be done with the engine in because my mechanic replaced mine, he did however say it was a bastard of a job lol
1989 Corolla GT sedan blacktop 20v
Cakky
Postby ChaosAD » Sun Aug 31, 2008 1:18 am
I think water leaks out of the hole in the bottem when the seal goes.
No need to pull the engine out.
Got to pull off the timing belt and covers though, might aswell replace the timing belt and tensioner while you have it off
ChaosAD
