ae101 brake question
Postby slammed_integral » Tue Sep 02, 2008 10:15 pm
will single pot brackets fit a twin pot caliper? any one have any ideas?
http://www.cardomain.com/id/slick_ep
there is nothing sour cola worms cant fix...
slammed_integral
Postby neo » Tue Sep 02, 2008 11:04 pm
Search is you friend
Short answer - not worth it, just get new std rotors and good pads.
http://www.toymods.net/forums/showthread.php?t=142
neo
Postby slammed_integral » Wed Sep 03, 2008 12:02 am
no, its for a conversion on my starlet, twinpots baby! jus seeing if i can get lucky and use some common single pot brackets. looks like im on the search :(
slammed_integral
Postby FLAWLES » Wed Sep 03, 2008 9:50 am
what are you trying to achive here?
theres a mod you can do ( i have some mounts here if you want $120 )
that you use bluebird u13 discs ( scimming the out side edge of your hub )
and hilux studs
alowes you to either run with ae101/111 twin pots ( i think the single pots have the same bolt spacing
the u13 disc is 260mm dia, so this still alowes you to run with a small dia rim ( no smaller than 14" )
or look here
http://www.club-k.co.nz/Forums/
or here
http://au.geocities.com/quibel_nz/Evo3_02.htm
on my starship race car i have done mine way diff, as i have lots of odd stuff in mine
FLAWLES
Postby FLAWLES » Wed Sep 03, 2008 9:51 am
this is asuming its a kp starlet and not a front tugs starlet
FLAWLES
Postby slammed_integral » Wed Sep 03, 2008 7:29 pm
yeh nah, its for my fronter ep.
slammed_integral
Postby FLAWLES » Wed Sep 03, 2008 8:24 pm
:roll: should have said that in the first post there brah
so egnore everything i have just said, no use to you
so will start again
for the piss arsing around you will incounter with calipers just upgrade the rotors and pads to a mintex 1166 ( cant rember the compond ) that will make a massive diff
FLAWLES
Postby slammed_integral » Wed Sep 03, 2008 8:52 pm
yeh i was thinking about getting some of those mintex but i figure i get some for the twin pots instead of buying 2 sets, but its a pretty easy conversion as far as i know, i was just seeing if single pot and twin pot caliper brackets are the same, to help make my conversion process easy on the wallet
slammed_integral
