what are you trying to achive here?
theres a mod you can do ( i have some mounts here if you want $120 )
that you use bluebird u13 discs ( scimming the out side edge of your hub )
and hilux studs
alowes you to either run with ae101/111 twin pots ( i think the single pots have the same bolt spacing
the u13 disc is 260mm dia, so this still alowes you to run with a small dia rim ( no smaller than 14" )
or look here
http://www.club-k.co.nz/Forums/
or here
http://au.geocities.com/quibel_nz/Evo3_02.htm
on my starship race car i have done mine way diff, as i have lots of odd stuff in mine
