Reading up on the ODO and Trips function is to "Buffer" the signal. I have no idea what this is.
The ECU gets its feed (Pink) from the ODO component.
Any help appreciated!
MrOizo wrote:Pin: 2
Colour: Blue - Red
Main Description:Vehicle speed signal for speedometer & odo trip meter #77
Explination:This signal goes to the speedometer and the odo and trip meter. The odo and trip unit will distribute the signal (buffer it). Blue - Red
Pin: 8
Colour: Red
Explination:Vehicle speed signal sender ground #77 Ground for the vehicle speed signal sender.
Pin: 23
Colour: Yellow
Explination:IG (plus) signal for alternator #68
Gauge (plus) for vehicle speed sensor #77
Gauge (plus) for backup light #116
matt dunn wrote:But that diagram does not look right for that sender.
Sender should have
a power feed ( 12v or 5V from dash, cant remember) Yellow and is 12v
an earth, Red
and a signal wire.Blue-Red
