Speed Sensor Wiring
Speed Sensor Wiring
Postby MrOizo » Fri Sep 05, 2008 11:48 am
Can someone tell me if i can some how bypass the "ODO and TRIP METER" from this diagram.
Reading up on the ODO and Trips function is to "Buffer" the signal. I have no idea what this is.
The ECU gets its feed (Pink) from the ODO component.
Any help appreciated!
MrOizo
Toyspeed Legend
Postby KinLoud » Fri Sep 05, 2008 9:19 pm
Buffer may mean - provide extra current... OR - change the shape of the waveform.
Can you try hitching it up directly?
My experience with my AA63 Carina... factory 4age bluetop got speed signal from a reed switch inside the mechanical speedo display. Signal was a square wave.
The gen3 3sge was looking for a sinewave generated by a magnetic pickup...
Just connected the square wave direct to the 3sge computer and it was happy as!
Ken
Auck
021 408 863
Postby jaypines » Fri Sep 05, 2008 11:31 pm
what car is that for? you might try bridging pins 5 & 6 of the odo/tripmeter and cut off the ground part (pin7). why do you want to bypass it?
jaypines
Postby matt dunn » Fri Sep 05, 2008 11:37 pm
From my speedo experience, all the pre 2000 toyota type ECU's all look for a square wave signal,
Normaly there is a signal from the speed sensor to the speedo itself, which can be any signal at any rate depending on the signal,
but the speedo itself outputs a square wave of a certain number of pulses per KM to the ecu.
And more correctly, the ecu outputs the voltage and the speedo head pulses the signal to earth.
Postby MrOizo » Fri Sep 05, 2008 11:49 pm
Well the thing here is that i have gone from a mechanical speedo to an electronic one.
Apparently the cable spins the wrong way for the MK3 Supras.
Since i cant really run the speedo cable, i was going to run the Apexi RSM insead. Tried hooking this up to the output from the sensor itself - (L-R) and no luck.. didnt register speed.
Going by the diagram and reading that the sensor grounds for signal, could i hook up the RED wire from the sensor itself?
I'll get more info which has been written online and post here.
Thanks for help so far
MrOizo
Toyspeed Legend
Postby matt dunn » Fri Sep 05, 2008 11:58 pm
post a picture of what type of speed sensor you are using and I should be able to tell you how to make it work,
anything like this one?
http://www.linkecu.com/support/dlandswu ... peedSensor
Postby jaypines » Sat Sep 06, 2008 8:50 am
looking at the diagram, the red wire is connected directly to ground. i reckon square wave signal would be from the blue-red (l-r) wire with an amplitude of 12V. try hooking it up with oscilloscope and see.
jaypines
Postby MrOizo » Sat Sep 06, 2008 11:24 am
Here is the info that i have been given from a site:
Pin: 2
Colour: Blue - Red
Main Description:Vehicle speed signal for speedometer & odo trip meter #77
Explination:This signal goes to the speedometer and the odo and trip meter. The odo and trip unit will distribute the signal (buffer it). Blue - Red
Pin: 8
Colour: Red
Explination:Vehicle speed signal sender ground #77 Ground for the vehicle speed signal sender.
Pin: 23
Colour: Yellow
Explination:IG (plus) signal for alternator #68
Gauge (plus) for vehicle speed sensor #77
Gauge (plus) for backup light #116
Here is a pic of the sensor (one on the left):
MrOizo
Toyspeed Legend
Postby MrOizo » Wed Sep 10, 2008 5:22 pm
MrOizo wrote:Pin: 2
Colour: Blue - Red
Pin: 8
Colour: Red
Pin: 23
Colour: Yellow
Well got under the car today and can only confirm that i had power on the yellow. No pulses from either of the other wires when the wheel was turning. :/
Hmmm....
MrOizo
Toyspeed Legend
Postby postfach » Wed Sep 10, 2008 5:56 pm
A digital multimeter may not be able to pick up the pulse. Have you got it set on AC or DC?
How are you turning the sensor?
postfach
Postby MrOizo » Wed Sep 10, 2008 11:56 pm
was simply a test light off both of the red and blue-red wires.
Was told to try this. is this like an induction type pick up rather than a reed? (thats if they are like that?)
Prob not a good test but was told to give that a shot.
MrOizo
Toyspeed Legend
Postby matt dunn » Thu Sep 11, 2008 12:09 am
Those type of sender are crap,
well they crap out all the time, have been on Hilux's and AE101's etc etc.
They all use the same head with a different length shaft and gear.
I was playing with one the same on a GT4 a while ago, but cant remember what pin was what off the top of my head.
Postby matt dunn » Thu Sep 11, 2008 12:36 am
But that diagram does not look right for that sender.
Sender should have
a power feed ( 12v or 5V from dash, cant remember)
an earth,
and a signal wire.
Postby MrOizo » Sat Sep 13, 2008 9:38 am
matt dunn wrote:But that diagram does not look right for that sender.
Sender should have
a power feed ( 12v or 5V from dash, cant remember) Yellow and is 12v
an earth, Red
and a signal wire.Blue-Red
Well managed to sort it out. all it needed was a ground and a re-wiring at the ECU to give it a feed.
Chru chur~!
Thanks for help peoples.
MrOizo
Toyspeed Legend
Postby rollaholic » Sat Sep 13, 2008 10:49 am
for future reference if you are using a filament type test light, alot of ECU type signals wont activate it as they are around the 5V mark. you need an LED type test light.
Users browsing this forum: Bing [Bot] and 13 guests
