wiring nightmare, 1ggte into gx81
Postby Jonno2002 » Tue Sep 09, 2008 1:08 pm
ive got the 1ggte wiring diagrams theyre easy to find, its the gx81 1gfe diagram i need now, toyota want $40 to translate and i dont have $40 to waste currently so has anyone got this diagram ? ive tried mx83 and that was way off, and im not gunna be a butcher and have switches on fuel pumps and the like i want it wired correctly hence the headache
Jonno2002
Postby Dell'Orto » Tue Sep 09, 2008 6:55 pm
Maybe PM tgb.mr2, he did that conversion I believe.
Postby Jonno2002 » Tue Sep 09, 2008 8:07 pm
yes he did, i have his "wiring diagrams" but he bypassed the fuel pump too, which i did today and the motor ran, so meh might just put a relay in for the pump who knows, its impossible to find the diagram for the car loom and im sick of chasing wires around the car
Jonno2002
1ggte
Postby docTRD » Sun Sep 14, 2008 12:23 am
in regards to the fuel pump wiring just trace back the wires from the intank pump of ur gx81 then locate them on the car body loom. The 1gfe is a map sensored engine whereas most 1ggte's are AFM so they use a different system to get the fuel pump going because the fuel pump is triggered by the AFM flap. As for water temp and all the other gauges i just traced back from the cluster to the body loom and to the motor, this was in a gx71 but im sure theyll be quite similar to gx81. see how you go
Daily : st191 corona liftback mmm room
Project : Jzx90 mark2 Tourer V
--- wtd: corolla GT ae92 sedan ---
"Mum i knw its another wreck, i only got it so i can put the seats in the lounge" YEAH RIGHT
docTRD
Mo Joe
Postby Jonno2002 » Sun Sep 14, 2008 12:04 pm
traced some wires, the water temp sender just goes strait to the top of the guage so thats a fail, ive lost my lower right warning lights (batt,check engine,check lights,exhaust temp) cant get them going to save my life, checked all fuses and pissed around with a multimeter for half a day, yes i know about the fuel pump im probly gunna just get a special relay and wire it up myself, i know some auto sparkys who have told me a bunch of things which helps, but man wiring certainly is the hardest thing in the world especially when i dont have a wiring diagram for the car, would make my life so much easier. think i might just have to go with all after market guages
Jonno2002
