st205 S/S ball joints?
Postby DaVe0r » Tue Sep 09, 2008 6:28 pm
hi guys
the celica is making one hell of a racket going over ANY bump now, got worse after trackday, go fig
sounds like something bashing in the front of the car both sides
im guessing its the ball joints as the car has done 128km now
found ya ball joint part numbers in bits from the superstrut faq...
but what are the expected cost for these from toyota? im going to have to use the visa for this :(
i can do all the work my self so no problem there
cheers dave
Toyota Celica GT4, 255Hp of Factory goodness
Ford Laser S KL-ZE Swap Track hax
Mazda Astina GT 138whp N/A *Gone*
DaVe0r
Postby RunningRich » Tue Sep 09, 2008 9:21 pm
Ask Toyota? :P
OK, I'll tell you! I priced the lower arms and Figure 8 arms at around $1200ish last month from Toyota. Not cheap! I'm only needing a Figure 8 arm at the moment so will have a spare rebuilt by Bricon.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby Crimson Tears » Tue Sep 09, 2008 9:23 pm
You should put the vehicle on a hoist and check the front suspension before you just start replacing components. You need to ascertain if it is the shock absorbers, the bottom arms or the links.
I did a ST205 Celica at work the other day, the customer wanted the shocks and links replaced, I replaced them and it was still knocking like mad, ended up being the LH bottom arm had movement.
Toyota has line priced all their shocks, by memory the shocks are around $200+GST retail each.
Crimson Tears
Postby lucasthefallen » Tue Sep 09, 2008 10:08 pm
Crimson Tears wrote:You should put the vehicle on a hoist and check the front suspension before you just start replacing components. You need to ascertain if it is the shock absorbers, the bottom arms or the links.
nope TGP shocks are $144+ each retial, bargin price!
Need Service or Repair work done? send me a PM
lucasthefallen
Postby DaVe0r » Tue Sep 09, 2008 10:11 pm
$1200 dam!
better double double check the banging noise
been on the hoist before, but i couldnt find it at fault
DaVe0r
Postby sergei » Tue Sep 09, 2008 10:18 pm
DaVe0r wrote:$1200 dam!
I have replaces 2x fig 8s, 2x lower straight arms, all added up to about $750, all Toyota Genuine. Banana arms are expensive, but usually they do not wear out and the bush is replaceable on other end.
Postby soven » Tue Sep 09, 2008 10:24 pm
have a search on superstrut. Off the top of my head, you have the car on flat ground and then hold the spring perch and try to twist it. It should not have any play.
soven
Postby DaVe0r » Tue Sep 09, 2008 10:54 pm
soven wrote:have a search on superstrut. Off the top of my head, you have the car on flat ground and then hold the spring perch and try to twist it. It should not have any play.
so if it moves its "blah" that failing? right?
DaVe0r
Postby Mr Revhead » Tue Sep 09, 2008 11:11 pm
nope $150rrp + gst :P brake rotors $144rrp +
have a chat to the forum sponsor for the s/s arms he wil be able to knock quite a bit off the rrp
Postby Prymal » Thu Sep 11, 2008 11:01 pm
heh - sounds like we all need a figure 8 group Buy ..
i certainly would consider it !
Prymal
